Has anyone welded cast turbo elbow i have
i have been fitting a zvh turbo in a mk2 escort estate and the turbo was facing the wrong way so i flipped it which ment i had to cut and reweld the elbow, do you think this will hold???
https://passionford.com/forum/pictur...ictureid=17875 https://passionford.com/forum/pictur...ictureid=17873 |
check out the rebuild https://passionford.com/forum/restor...-rs-turbo.html
doubt it :grin:
i woulnt want to chance it
Only know of one job like that that held he heated the item in his oven then got it well hot with a torch done the weld then back in the oven for hours on a slow cool down all was good it was on a mgb with a tubo d 1.8 in it
https://passionford.com/forum/pictur...ictureid=17876
whats the best way to stress it cos iv heated it back up and been hitting it with a hammer to try and crack it does anyone no what its actually made of? because with the mig on its highest setting it welded perfect, not one crack and penatrated rite through |
Did you use special rods for welding cast iron ?
Originally Posted by mk1turboestate
(Post 5293268)
no, i used a mig, not sure what the actual content of steel to iron is?
the car wont run for a few months anyway but i need something for mocking up, but was hoping it mite work |
Have a word with a good welder cos I think that just wont hold
i have spoke to a couple of welders but they said just try it, i no somebody who can cast weld it for me and mite end up doing that at a later date but i wanted to no if anyone had tried it, u never no
anybody done it?
My mates got a t16 turbo engine which has a td04h from a evo welded onto the standard cast manifold, thats non gas mig'd on and thats holding PMSL
i know a guy the modded a standard let turbo manifold, cut it at the kneck and welded a t3 flange onto it, he heated it up before hand to try and stop is cracking, then used mig brazing wire on it, think it held up for ages but he suported the turbo so there asnt alot of stress on it.
Mig weld is no good on cast mate,it needs to be done with a cast rod mate and there are not many peeps around who do it well thats in nottingham anyway i found two companys that would do it and it's not that cheap i had my old mans cosworth manifold done it had a 2" crack in it and it cost about £50.
its not the actual manifold, its the elbow that goes down to the downpipe, i used gassless mig wire because i read that this works better,
does it crack straight away? i heard no tink tink noises and the welds are still perfect, it also penatrated really well so was wondering if it had i high steel content |
When the steel from the mig cools down it does so much faster than the cast and contracts, you may hear some tinkling noises coming from the casting as it cools, the noise is cracks forming, the best way to weld cast with mig is to braze it, you need to heat the cast up to over 700degrees and then let it cool down very slowly in an over to save the cracking. BUT mig is by far the best way to weld cast and it should be done properly.
well i suppose i will leave it for now, anybody no a good way of testing it?
eg. heating it up and knocking it? |
not Sure if it'll hold mate we do a bit of work restoring old gates and the like. Normally we'd just grind out the crack heat the whole item till it just starting turn red weld it with a dissimler metal rod them keep gently heating it and leave it in a bucket of sand to cool down, Migs are normally notgreat for cast cause all the heat is concentrated on one spot.
BUt on the other hand ya might be surpised a lot depends on the actuall iron nickle content and other things in metal |
thats what im hoping for, but cant really test it till i try it
put it on and see if it works, if not then back to square 1 lol
As capri zetec 170 says, best heating the material before welding and then using a dissimilar welding rod with an arc welder, not mig and let cool down gradually, this is the best way for cast materials.
to late lol, i pre heated it and cooled it down slowly but used a mig with fluxed core wire on the hottest setting, got no cracks and no noises, if anything it welded perfect like to pieces of steel,
Fuck it pal try it, prove us wrong lol, if it fails get a t34 and use a cossie ss down pipe :)
ive welded cast with mig before using the heating cooling method with an oven and have had no problems allthough i have heard of the cast exploding before when cooling! not nice if its under your bonnet!!
im going to wrap the elbow tightly anyway just in case cos i dont want it dropping near the paintwork,
ive welded cast before with a mig and has been fine, just heated it up till it was glowing, also filled a chamfure on to both faces to get better penatration.
that was welding a zetec flange onto a rs turbo manifold and it was fine, give it a go, it it leaks \ cracks then you can use it to mock up a steel one, just get some flanges and a bit of bent tube. lee |
Originally Posted by zippyobrien
(Post 5294372)
that was welding a zetec flange onto a rs turbo manifold and it was fine, give it a go, it it leaks \ cracks then you can use it to mock up a steel one, just get some flanges and a bit of bent tube. lee nice to see somebody who its worked for, i cant do it in steel tho as its part of the wastegate housing did u have any cracks or problems? |
i know its the elbow your on about i was just saying that i had a cast manifold done as cast is cast at the end of the day
ran the manifold for ages and it was fine,
all i did have to do was skim it flat on a mil as i warped it a little bit, bit that dont apply to your application |
gives me hope mate nice one, seems strong to me anyway but will be months till i run it
leave it out side, let it weather'
thatll show if its strong or not lol |
thanks for everyones input, guess i will just try it n hope for the best, couple of people have had positive results so hope i do!!
thats a good read, i tried for hours to find something like that
© 2024 MH Sub I, LLC dba Internet Brands
