xe into a sierra sapphire 1.8 has anyone done this is it a easy conversion& how much
Has anyone done it before
Probably, easy enough to do.
You will need either a manta gearbox or a bellhousing adaptor to convert the xe to type 9 fitment. Distributor is the only issue but if its going on throttle bodies you won't need one, if your using a standard engine use the later coilpack engine as the phase sensor doesn't stick out far. |
Ive not done it, but have seen it done, its pretty trivial TBH
The wiring is just half a dozen wires, the engine goes straight onto an adaptor plate SBD sell for a type 9 box. Then you just need XE rwd bits basically. Not sure I would bother though! I love the XE, always have done, but its getting pretty long in the tooth now! |
Fit a Honda S2000 engine instead
Originally Posted by JonnyBravo
(Post 5287192)
Originally Posted by Chip
(Post 5287196)
Exactly!
(Post 5287204)
I know where there is a lovely one for sale as well :cry:
(Post 5287222)
You buying it to replace that fucked one you are getting rid of?
But of course :top:
(Post 5287250)
But of course :top:
I wanna give a conversion a go but not a 2.9 cosworth in my sapphire
Any body with any ideas could you get as much info as possible and not just say a engine type would like to know whats needed and what work i need to do etc |
Originally Posted by barrychambers30
(Post 5287290)
Any body with any ideas could you get as much info as possible and not just say a engine type would like to know whats needed and what work i need to do etc https://passionford.com/forum/restor...rra-2wd-3.html Mark |
© 2024 MH Sub I, LLC dba Internet Brands
