Series 1 4x4 cosworth
#1441
That was my worry too. I have a tendency to buy the parts o need and find out there's problems with them. So does the S and J head come all ready flowed ported and correct sizes etc for the build? Or is it a std size and Pierro would have to do his work on it too? Therefore adding more costs?
I believe the S and J head comes "optimised" for flow, the only argument being if the valve and port sizes were too large would you lose speed of flow etc...Rod will be the first to say that his car made 7 gazillion horsepower without the need for bigger valves but as I understand it (in my basic terms) there was a feeling that if the barrels were larger then the head shape could cause a shroud whereas the S and J heads allowed for this???
The good news is that it would only need a clean up and pot matching for inlets and maybe a quick port so should not cost the earth.
I am sure S and J will provide this info based on the high spend
cutch (12-01-2017)
#1442
The best way to look at there head is it's a new casting and sj porting to it so it's not night a day diff and it's airflow is what sj are happy with the results they get. Which will be diff port sizes and airflow that than other tuners and head porters do as we are all diff.
Mark
The following 2 users liked this post by Mark Shead:
Caddyshack (12-01-2017),
cutch (12-01-2017)
#1446
Yeah, sounds really good. What did you do the 0-60 time in?
#1447
Thanks guys, I actually can't remember the time, 3.85 is ringing a bell?? I hadn't ever done it before and kept launching with the revs too low and it would bog down. Eventually I thought fuck it and pinged the clutch at 6k revs and it took off! The grips it's got is mental.
In two minds after watching the video to take the box etc out or leave it. I have collected all the std stuff to put back on.
I dont know....
I dont know....
#1448
I dont know....
I dont know....
My Oppliger is semi straight cut and makes some nice noises, it is a little loud at times but I don't have carpet yet (just dynamat until the carpets are made) not sure how much louder your box would be but if you want to run proper power you are going to break the std one.
#1449
Yeah mines loud too, very loud in fact. It's nice to see the looks of confusion but it's horrible to drive normally. I had never launched it before even though the cars set up to do it. I felt like I was going to break it which is probably daft but hey it's my baby. I started at 4K and it just bogged down, was useless at any revs below 6k. I had a few tries and each time I would bump up the revs a little until the run above which kinda nailed it. Would have been better I think if I just gave it full revs and dumped the clutch!
#1450
I have booted mine in 1st and the rear end slides out (probably poor geometry) but it feels so brutal in first. My car feels best in 4th and it takes off like my 2.0 gti 205 does in 1st or 2nd.
I am pretty sure that 5000 rpm and step off the clutch will be mid 3's unless it destroys something
This has quaife front New diff and supra weir so all 4 wheels are locked up tight
#1452
I have the close ratio semi straight cut oppliger "long" box. It is noisey in some gears under full load but not deafening, I can hear the sat nav and the CD playing in the car.
#1455
It took me ages to buy the ramps and now I realise I should have bought them years ago.
#1460
I've got 4x4 Granada hubs there for it glen. I'll get it mocked up and see what I need to do with the brakes. I wanted the series 1 wheels without having to use spacers or cut material off the wheels. So I'm going to give it a shot with these and hopefully the cossie brakes will fit in behind the Granada wheels a lot better.
#1464
For ages I have had a battery that dies on me after a few days or even less, this has not really bothered me because it's kinda handy not being able to start it as I'm away all the time so thieves would have about as hard a time as me getting it started!!
I decided to buy a new white flat top battery that I saw on eBay and stick a sticker kit on.
I was convinced that the car wouldn't start very well when you turned it over due to a weak battery even when charged so went for the bigger battery and put new acid in and charged it. First throw and it seemed perfect, fired first time. Usually it has to be cranked over for ages, I was told this was due to the big injectors but that didn't seem right? Anyway, new battery does the bloody same. Dead after one day! I must have a drain somewhere, driving me nuts.
Also decided to make the engine bay more stock looking so whipped out the cone filter and tried to fit a panel filter.
Stock filter sitting in place.
It wouldn't fit! I need to remove my turbo heatshield and hopefully it will fit, easier said than done, I also have the problem that my engine bay is slightly narrower than a sierra so I'm still not sure that will be enough. I have an old crappy stock heatshield here to try too so that might get in the way... oh the joys..
#1465
Received 1,042 Likes
Nightmare about the battery. I know my battery goes flat after about 2 weeks if i dont touch the car.
Im not that keen on the standard air box matey. I dont know if its the pic but the airbox looks massive in the engine bay???
#1466
This weekend I took out the supra diff and put it onto my track car
Finally out on the driveway
Installed in the track car.......after alot of messing about.!
This week I'll take off the straight cut box. It's now sold, I'll miss it, loved the thing and if I ever go for another I will be phoning Bara back up, service is second to non!
Need to clean up the standard diff and gearbox I've got and install with a standard clutch. Not sure what clutch to go for? Going to bring the spec back down to standard T3 I think, so don't need one for a lot of power and want something that's more comfortable to drive?
#1467
That diff cover looks great on there, the ford motorsport bit really sets it off.
#1468
Glad to hear you got the straight cut box sold, hope you were happy with the money you got for it. Not sure if this is of any help but as far as I know I use a standard 4x4 clutch in mine and that's been dyno'd at 348bhp at the hubs and seems to be fine and quite light under foot. I'm sure the reduced weight of the car will help the clutch deal with the added power. I'm running a T34.63.
#1470
Yeah mine didn't fit either. In fact quite a lot of it didn't fit! Was a total pain to install on the car. I've heard of quite a few people saying the same thing now that I have mentioned it.
The diff cover was nice, my supra cover was scabby. Unfortunetly the covers holes didn't line up perfectly either! Had to mess around a little to make it fit too......
#1474
My MK cover went straight on, no probs. What make is the one you have? Looks MK to me.
I wonder if there is a certain amount of tolerance in the original castings of the diffs?
#1475
Mk mate. The smaller bolt holes, M10 I think didn't line up too well, had to kinda force it on eventually. I don't know, maybe the castings are slightly different. Had to cut more off the casing to get the different top plate (7.5") to fit. Wasn't amused about that either, didn't need to buy more shaft adapters as the originals have holes for 4x4 and 2wd! Didnt need the bloody things! Once it's on it's great does the job, I've got a brand new supra diff (internals) and I expect it will do well but my plan was to have different ratios for different tracks......f**k changing that over each time!
#1476
Yeah got the money I was wanting. If I didnt I wasn't going to sell it. The box is great, I really would have built another car around it, not very sensible money wise but I loved it. Unfortunetly the next build will be a 3dr so it didn't suit. Which make of clutch is it mate?
Unfortunately I have no idea what make the clutch is, I even had it off once and can't remember seeing anything on it. Sorry I know that's not much help. If I was to replace it I would buy a 'standard' described clutch from a manufacturer like AP or similar.
#1477
Time to take the gearbox out
Strut brace and heat shield off to get the down pipe off
Then under the car to take out starter, bolts for gearbox and the Hyd clutch.
Then because I was a bit grubby I thought I'll pack up and do the centre consol, gearstick tomorrow when I'm clean etc. Should be just the cradle and prop mount to pop off and the gearbox will be out. Stupid f**ker that I am, I lowered the bonnet down to low and my tooltray made a nice little dent through it!!! It was at this point I called Gibby and booked a full paint job back to diamond white as I was making the car as standard as possible. F**k it!!
#1480
Well I got the gearbox out, was a nightmare job lying on the floor. Never doing that again without a ramp! Not sure but it seemed like on my car the bulkhead is closer to the back of the engine than a sapphire? So when I tried to tilt the engine back slightly to help pull the gearbox out it didn't bloody move! Had to take the anti roll bar off and lever it down while I pulled the box back. Well when it goes back on it will be fully built up and I will lower the car over engine/box/suspension etc in one go.
