ZX10R turbo kit car build - update 10-08-13
Old 16-04-2012, 09:59 AM
  #561
lanfire
lanfire's Avatar
as above amazing detail
Old 16-04-2012, 11:46 AM
  #562
Garage19
Garage19's Avatar
Originally Posted by Red16
I made a base plate for the sump and tacked it in position, it has a drain hole tapped into the corner to allow the oil to bedrained from thecentral sump area. I'm not sure if i'll redo this plate and have the drain hole in the side to give a shade more ground clearance.
Great build. Couple of tips for you that will make your ally welding easier.
First of all, get your foot pedal working. Ally will need lots of amps to start and will reduce right down as you go. It is VERY difficult if you have to run a static current through the weld procedure.
Second is you will find it easier if you set your joints up differently before welding. For an outside edge you need to set the sheet metal edge to edge so thet you have a 3mm vee with your 3mm material. You will get a stronger joint and it will also help you control the weld pool direction. So cut through the tacks, pop that last part off and take 3mm of material off each edge.
Old 16-04-2012, 10:38 PM
  #563
Red16
Red16's Avatar
Originally Posted by escort1989uk
That's very sweet work the detail to everything is better than some engine builders. Let's hope it's going to take the abuse a lot better than last time
Thanks a lot
Originally Posted by DaveCrack
Thanks for explaining everything in detail! Some real good knowledge is being told here! Keep it up!!!!
No problem, i'm happy people are enjoying reading it
Originally Posted by J1mbo
Good work fella! Have you done ring gaps?
Cheers, yeah all sorted, they were already gapped as they've been ran in the engine for a good few miles but worth a quick check.
Originally Posted by NEEDFORSPEED
How's your little car coming along?
Thanks for the tips, once the car is back on the road i'll give them a go! I want to have a good practice, get myself up to scratch.
If I could guarantee to have the time away from work, I would do a TIG welding course at college, but I wouldn't be able to make all the classes, it's a shame as I'd love to do it and would obviously benefit a lot.
Old 16-04-2012, 10:39 PM
  #564
Red16
Red16's Avatar
Transmission shafts assembled, sealant applied to the lower engine casing and then the two were put together, bolts/washers fitted and torqued, then the generator, clutch, oil pump, water pump etc were fitted.
The sump is now finished and fitted.
The next things on the to do list are the starter motor and it's gears/covers, then the timing chain and cylinder head, it's getting there now.
Old 17-04-2012, 06:39 AM
  #565
NEEDFORSPEED
NEEDFORSPEED's Avatar
its not mate only need wheels and mapping aswel! once the kitchens finished il be back on with it, youl just be in good time for the weather and love the sump!
Old 17-04-2012, 09:24 AM
  #566
lanfire
lanfire's Avatar
looks really well that matey i wish i could weld
Old 14-08-2012, 12:56 PM
  #567
Red16
Red16's Avatar
Here's a small update, I got the cylinder head and cams fitted, then timed it all up.
The old exhaust manifold wrap was very flakey and had started to fall off so I removed it to start again, but found the manifold had cracked in numerous places around the collector, doh! It's since been repaired and is ready to go, when I get some free time.
Old 14-08-2012, 02:16 PM
  #568
lanfire
lanfire's Avatar
good stuff mate, pluggin away !
Old 31-03-2013, 06:08 PM
  #569
Red16
Red16's Avatar
I forgot to update this thread a while ago, the manifolds were fitted to the engine, engine put in the car, exhaust fitted and everything plumbed in.
Today the weather has been canny so I've had the car outside on the drive and got the engine running, nice to hear it again
Old 31-03-2013, 06:36 PM
  #570
scarnny
scarnny's Avatar
Good work mate, cant wait to see this up and runningagain.
Old 06-06-2013, 10:26 AM
  #571
scarnny
scarnny's Avatar
Any updates on this?
Old 16-06-2013, 09:01 PM
  #572
Red16
Red16's Avatar
It is now
It's currently having an MBE 9A4 ECU fitted
http://www.sbdev.co.uk/Engine_Manage..._Technical.htm
an MBE 995 dash display
http://www.sbdev.co.uk/Engine_Manage...995/MBE995.htm
some extra sensors have been fitted to suit the ecu, a charging issue and a couple of wiring issues have been rectified and mapping has been pretty much completed.
Last time on the rollers at Daytuner it made 198bhp/101lbft @wheels on 8psi, speaking to Damien at Daytuner last week he said it's now doing 222bhp @wheels on 8psi and around 250bhp @wheels on 14psi, i'll have graphs and more info next week when I collect it.
Apart from the slight increase in power with the new ecu setup, the car starts on the button and runs smooth as can be, i've not witnessed it for myself yet but it pulls nicely from low down right through the revs/gears, can't wait to have it back home!
Old 16-06-2013, 09:16 PM
  #573
cozzy jeff
cozzy jeff's Avatar
Ben it was awesome fast when you took me out in it, it must be immense now.
Cant be much that can touch it mate.
Old 17-06-2013, 08:48 AM
  #574
scarnny
scarnny's Avatar
Great news mate we need some vids when you get it back.
What did you do with the clutch? As my brother has an R1 car the same as your and it keeps eating clutches.
It has the barnett coversion on it apart from plates and springs, just wondered what you are using as youve got much more power.
Cheers andy...
Old 25-07-2013, 06:45 PM
  #575
Red16
Red16's Avatar
It certainly feels pokey
Cheers andy...
It's got a lock up clutch, which consists of an additional plate that goes on the end of the clutch with weighted arms mounted on pivots on that plate, as the engine revs up the weighted arms get thrown outwards and apply pressure to the clutch plates to combat clutch slip.
http://www.mtceng.com/products/mtc-p...ck-up-clutches
Old 25-07-2013, 06:46 PM
  #576
Red16
Red16's Avatar
Today I took advantage of the nice weather and bonded mesh to the bonnet, here's the finished article
I also cut 1/3 off the bottom of the intercooler to allow more air to the radiator, when at steady throttle on hot days the water temp was reaching and settling out at 102 degrees C but the inlet charge air temp was 37 deg C max, around 5-7 degrees over ambient air temp, so it looks like the cooler is more than up to the job, hence deciding to reduce the size a little.
Here's how the intercooler currently looks
Old 25-07-2013, 07:03 PM
  #577
cozzy jeff
cozzy jeff's Avatar
nice work as usual mate
Old 28-07-2013, 09:48 AM
  #578
Red16
Red16's Avatar
While the car was at Daytuner the following things were carried out,
Fuel injectors cleaned and tested.
A charging issue was rectified.
Power Commander and all associated wiring sensors removed.
MBE 9A4 ECU and required sensors installed and mapped.
MBE 995 dash display fitted to the steering wheel.
The Davies Craig water pump, radiator fan and turbo cooler fan were all wired up to an ECU output to allow them to all run according to temperature, the water pump also runs on after ECU turned off to aid turbo cooling.
Here's the MBE 995 dash display fitted to the steering wheel, it displays gear position, boost/vacuum pressure, coolant temperature, oil pressure, RPM, air charge temperature and battery voltage, it also has shift lights at the top and warning lights at the bottom.
Old 28-07-2013, 09:50 AM
  #579
Red16
Red16's Avatar
Yesterday I got on with modifying the intercooler.
I made an aluminium plate to seal the bottom of each end tank, they were a snug fit so they pushed nicely into place, here's one in position
Welded up, not perfect welding but I'm happy my TIG welding is improving
The finished intercooler
With the mesh in the nose cone removed, you can see how much more radiator is now exposed
The car was built back up and taken for a test drive, it was a scorching hot day, water temps maxed at 90 deg C while driving and 92 deg C in short traffic jams, air charge temps were around the same as before maxing out at 39 deg C.
All in all I'm really happy with the days work!
Old 28-07-2013, 09:23 PM
  #580
Red16
Red16's Avatar
Shortened the sump today, gained around 20-25mm of ground clearance, so bottoming out should hopefully be a thing of the past
Will get it fitted and tested out tomorrow if the weather improves.
Old 29-07-2013, 11:50 AM
  #581
DaveCrack
DaveCrack's Avatar
Great to see how you keep constantly improving things on this car! Keep it coming and enjoy it.
Old 01-08-2013, 09:18 PM
  #582
Red16
Red16's Avatar
Thanks Dave
Old 01-08-2013, 09:47 PM
  #583
Red16
Red16's Avatar
Tested the new sump modifications out the other day, gave the car a good run out, everything appears well, no leaks, oil pressure looking good etc.
Unfortunately later on the car began smoking, mainly as it came on and off boost, the turbo was the most likely cause but further investigation was required.
A compression test of the engine showed 155psi on all four cylinders proved the engine was ok.
Took a boost pipe off and found oil inside, then took the K&N off the compressor housing and found oil in the inlet!
I've been in touch with Owen Developments today and I've bought a GT3071R core with metal bearing cage upgrade and a new ported compressor housing as my current on is too big, i'll install that core into my current turbine housing before fitting to the car.
Old 02-08-2013, 08:49 AM
  #584
scarnny
scarnny's Avatar
Whats causing this?
Old 02-08-2013, 03:26 PM
  #585
Rob_DOHC
Rob_DOHC's Avatar
Whats causing this?
The car is obviously too awesome for the turbo to handle.
Great work mate, love looking through your pics!
Rob,
Old 03-08-2013, 10:16 AM
  #586
Red16
Red16's Avatar
Whats causing this?
The turbo simply expired I presume, there is definite play in the bearings when you move the wheels/shaft.
I'll inspect the old turbo core when I've got the car back on the road.
Rob,
Haha, cheers Rob.
Old 03-08-2013, 10:22 AM
  #587
Red16
Red16's Avatar
Here's the new GT3071R turbo CHRA and ported compressor cover which arrived yesterday
Last night I removed the old turbo ready to strip and fit the turbine housing to this new core.
Old 03-08-2013, 09:23 PM
  #588
Red16
Red16's Avatar
This afternoon I removed the turbine housing from my old turbo and gave it a clean up, here it is alongside the new GT3071R assembly
The up pipe from the old turbo compressor housing was cut off and cleaned up ready for welding to the new compressor housing.
Here's the new GT3071R, the old GT3076R and the up pipe
I didn't take anymore photos today, but in a nutshell the turbo has been refitted, along with the exhaust, coolant hoses and oil hoses after priming the turbo with oil.
Old 03-08-2013, 11:25 PM
  #589
Rob_DOHC
Rob_DOHC's Avatar
How did you learn to TIG btw mate? Did you teach your self.
I can MIG averagely well and have been considering buying a TIG for ages now, just put off by the steep learning curve I keep reading about
Rob,
Old 04-08-2013, 07:04 AM
  #590
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
What a work of art, how I missed this build before I don't know
Old 04-08-2013, 12:09 PM
  #591
LIMITLESS
LIMITLESS's Avatar
Good progress mate, looking very good
Old 10-08-2013, 10:03 PM
  #592
Red16
Red16's Avatar
Rob,
I'd done a little bit of oxy/acetylene welding in the past and always wanted to be a TIG whiz so bought an AC/DC setup and had a bash, I'm a long way off being a whiz but it seems to getting easier everytime, one day i'll be good at it, lol.
Cheers man
Thanks dude
Old 10-08-2013, 10:04 PM
  #593
Red16
Red16's Avatar
Sorted out an external exhaust today to help with the issue of stinking of fumes after every drive of the car, test drive proved it works
It's a lot quieter at idle but not too different at full chat.
Old 11-08-2013, 11:24 AM
  #594
NEEDFORSPEED
looks ace that!
Old 11-08-2013, 05:05 PM
  #595
fezzajsy
fezzajsy's Avatar
looking good
Old 11-08-2013, 11:57 PM
  #596
Rob_DOHC
Rob_DOHC's Avatar
Thanks mate I think all the welding looks superb especially considering how quickly you seem to have picked it up!
What tig set did you buy? Make and model etc.
Thanks
Rob.
Old 12-08-2013, 10:30 AM
  #597
Red16
Red16's Avatar
Cheers boys
This is the TIG welder I bought
http://www.r-techwelding.co.uk/weldi..._R-Tech_Tig201
Here's all their range of TIG welders
http://www.r-techwelding.co.uk/weldi...ent/Tig_Welder
Old 12-08-2013, 03:15 PM
  #598
Looking good.Shame about the turbo spitting its dummy out.
Old 12-08-2013, 05:12 PM
  #599
Rob_DOHC
Rob_DOHC's Avatar
Great thanks very much
Rob,
Old 21-05-2014, 12:12 PM
  #600
R-A-J
R-A-J's Avatar
any updates on this beast?
JoeyBoyden
04-01-2024 02:36 PM
manuel boeckx
13
03-10-2015 02:29 PM
Dr. Ickxs
15-08-2015 11:34 AM
turbobill
09-08-2015 05:21 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: ZX10R turbo kit car build - update 10-08-13
