(COLEYST200) focus to focos / skyline gear box
Old 30-03-2010, 03:30 PM
  #121
dingla rs
dingla rs's Avatar
must be nearly finished with the welding now ian???
Old 30-03-2010, 07:16 PM
  #122
COLEYST200
COLEYST200's Avatar
no mate iv not sean the car for about 2 weeks now as iv had a lot of problems with my 3dr and like you iv been working away from home a lot and iv got a lot more working away this year and its all down london . when i get of work tomorrow night im doing a 140 mile round trip to pick up a 4x4 box that might be going into it . my 3dr cosworth is top of the list at the mo but when i get time i will back on it asap . your shell is coming on very nice now
Old 30-03-2010, 07:33 PM
  #123
dingla rs
dingla rs's Avatar
i bought a 4x4 box for me own shell only for it to drop off pallet so its feckd brakers gave me money back tho lol,yer slowed down me self as mate took his welder back for week or so,an not much i can do strut tops need welding underneath before filler work ,also mates rs turbo is on me spit you'l have every thing then bar engine ?
Old 31-03-2010, 08:50 PM
  #124
COLEYST200
COLEYST200's Avatar
well when i left work tonight i went on a 140 mile round trip and got a 4x4 gear box that might or might not go into the focus i just dont no still but iv got one if i do go 4x4
Old 31-03-2010, 10:23 PM
  #125
Jumbo
Jumbo's Avatar
Nice 1 mate.... wondered how this was coming along? If your in sunday i'll pop round and catch up
Old 31-03-2010, 10:30 PM
  #126
COLEYST200
COLEYST200's Avatar
i think i will be around mate just give us a ring first we need to have a beer and a chat mate its been to long
Old 01-04-2010, 01:35 AM
  #127
fezzajsy
fezzajsy's Avatar
Old 04-04-2010, 09:56 PM
  #128
COLEYST200
COLEYST200's Avatar
Right as some of you might no iv had a very very BIG problem with this build as we put a block and gear box under the shell and it didnt fit so i had to make my mind up wot to do well this was the out come .
One min we had this
Then we had this
as you can see it all had to come out to sort which im NOT happy about well then it went back in
And we now have some space around the front of the bell housing which was the problem
So all good now but iv now got a nuver problem as you can see the gear box is now of to the one side
the only thing i can think it is that is causesing this is the gear box cradle i can mod it but it just seams to be one thing after a nuther . and befor any one says the tunnel must be out trust me its in the center of the shell .
Old 04-04-2010, 10:10 PM
  #129
c20tbo
c20tbo's Avatar
Bit of head scratching with this one then, thats the joys of having a jig with all mount positions set, must be a reason for the box to be offset i would imagine, u'll get there yet.
Personally i wouldnt have tackled such a job without some sort of reference point jig. Hope all goes anyhow with the build.
Old 04-04-2010, 10:28 PM
  #130
COLEYST200
COLEYST200's Avatar
i should of never welded the tunnel with out having a block and box under it but i did and im now paying the price for it but i wont give up on it im going to see it throw to the end
Old 04-04-2010, 10:31 PM
  #131
focus 4x4
focus 4x4's Avatar
Ever thought about putting a complete sierra floor in in one piece?
Makes life a little easier in the long run.
Old 04-04-2010, 10:38 PM
  #132
xr4x4rs
xr4x4rs's Avatar
ill get you a pic tomorrow of my gear stick to show where it sits in the hole to give you an indication
but have you had the gearbox cross member off? as if its on th ewrong way round it moves the centre of the gearbox out of alignment
Old 04-04-2010, 10:41 PM
  #133
COLEYST200
COLEYST200's Avatar
no mate iv not unless the chap i got it did im going to have a look tomorrow
Old 04-04-2010, 10:45 PM
  #134
xr4x4rs
xr4x4rs's Avatar
ill sort that pic out, but the gearstick should be centre, it looks too far back but then it may not be in neutral lol, other than that it should bolt up straight
if your convinced the tunnel is straight then the only reason for that box to be off like that is the engine is off alignment aswell
Old 04-04-2010, 10:53 PM
  #135
COLEYST200
COLEYST200's Avatar
the motor is spot on and allso it would have to be a long way out to do this as the gear box bolts to the tunnel right underneath the gear stick
Old 04-04-2010, 10:54 PM
  #136
COLEYST200
COLEYST200's Avatar
allso will the gear box mount fit on the box the rong way round
Old 04-04-2010, 10:56 PM
  #137
xr4x4rs
xr4x4rs's Avatar
gearbox mount will go on either way but the cradle will go on 2 ways
Old 04-04-2010, 11:01 PM
  #138
COLEYST200
COLEYST200's Avatar
i am hopping this could be it mate
Old 04-04-2010, 11:39 PM
  #139
whizzisat114
whizzisat114's Avatar
bad luck with the floor having to come out
Have you got the rear end in and lined that up yet?
you gonna mock it all up before you weld it all up again?
Old 04-04-2010, 11:53 PM
  #140
COLEYST200
COLEYST200's Avatar
do you mean the rear beam if so yes its in the car and done
and the floor is only tacked in at the mo but it was all welded in
Old 05-04-2010, 12:06 AM
  #141
marco polo
marco polo's Avatar
good project col ......
Old 05-04-2010, 12:12 AM
  #142
whizzisat114
have you made the rear mounts or used the cossie floor pan? how easy was it to make the raer turrets and get them ligned up?
Old 05-04-2010, 12:36 AM
  #143
whizzisat114
just read the tread dont bother answering the one about the floor pan
could do with some pointers on the rear turrets if you would'nt mind.
Old 05-04-2010, 10:15 AM
  #144
dingla rs
dingla rs's Avatar
as said the front tunnel looked low that musta been al that was rong?? the rear turrets are a rite cunt to get rite let me tell you ther angled forward and inwards ,looks like it was easy fix anyway ian
Old 05-04-2010, 10:33 AM
  #145
COLEYST200
COLEYST200's Avatar
its juts a shame iv go so mch welding to do no and plating up as it was a very neet job befor now its not going to be as nice but it will be strong when it all welded up again . just got to sort the gear box out today and see why its of to one side
Old 05-04-2010, 10:45 AM
  #146
dingla rs
dingla rs's Avatar
never tryed out in mine an its all finished lol ,do like the mod for box inside tunnel andy moded mine with heat an hammer ,if ther out i can measure or check let us no ian ,it will be worth it in end
Old 05-04-2010, 06:52 PM
  #147
COLEYST200
COLEYST200's Avatar
right then been down to the car todat for a bit and im now very happy with wot iv done .
the gear box is now in the center of the tunnel
all so done the fab work to cover the 4x4 gear box
allso made a start on welding the floor back it
and allso done a small bit on the cradle that hold the dash bored in place
Old 05-04-2010, 07:18 PM
  #148
xr4x4rs
xr4x4rs's Avatar
what was the problem then
Old 05-04-2010, 08:11 PM
  #149
COLEYST200
COLEYST200's Avatar
the truth is i dont no its as if the gear box cradle is rong in some way and it will only fit one way round so i redrilled the cradle to soot and all is now good . as you can see we have put string line from roll over jig to roll over jig and its all spot on now so it will have to do
Old 05-04-2010, 08:54 PM
  #150
whizzisat114
Gonna mok mine up tomorrow so fingers crossed just got back from leicester to pick up some engine mounts and the n/s engine mount,
Coley how come you've had to mod your tunnel for the 4x4 ?
was it a 2wd tunnel you used?
Old 05-04-2010, 09:03 PM
  #151
COLEYST200
COLEYST200's Avatar
yes mate 2wd tunnel . i was going 2wd to start with but im now going 4x4 as i keep winning bits on EBAY for fuck all . got a good 4x4 gear box Ł50 4x4 sump Ł15 front diff Ł15 ok its all pluss post but still cheap
Old 05-04-2010, 09:15 PM
  #152
busa bob
busa bob's Avatar
Default focus
Tell me whizzisat114 are you building a focus 4x4 cosworth then lol
Old 05-04-2010, 10:26 PM
  #153
whizzisat114
Yes m8 i am well im gonna give it a dam good go ant way
If i could get this shitty three door off my drive first
Old 05-04-2010, 10:29 PM
  #154
whizzisat114
OH busa bob
i for got to tell you when you was here.
i ordered the last focus rs splitter of ebay this morning should be here soon
Just won a recon rear drive shaft for a tenner
Old 06-04-2010, 10:53 AM
  #155
Zanderford
Zanderford's Avatar
looking good so far really need to pull my finger out on my fiesta ull have done 2 cars before ive dun one lol
Old 06-04-2010, 09:20 PM
  #156
whizzisat114
coley I put engine and box in mine today and there does'nt seem to be a gear box mount all there is under the floor is a strenthening weldment with long elongated holes with no threads. is this normal?
ive made a rollover jig today and got the car up on it so it'll be belly side up soon and smoking from all the welding
Id forgot how much i enjoyed modifying cars
Old 06-04-2010, 09:38 PM
  #157
dingla rs
dingla rs's Avatar
get some pics up or a build thread not much cop just saying what you doing
Old 06-04-2010, 09:44 PM
  #158
COLEYST200
COLEYST200's Avatar
if he dose not i will as iv just found out this car is about 2 miles away from me so i will have to go and see it in the flesh ASAP
Old 06-04-2010, 09:46 PM
  #159
whizzisat114
how do i get pics on the thread?
Old 06-04-2010, 09:50 PM
  #160
COLEYST200
COLEYST200's Avatar
set up a photo bucket acount
Quick Reply: (COLEYST200) focus to focos / skyline gear box
