Standard Series 2 Escort RS Turbo to Cossie Managed. EsCos wheels fitted.
#43
mostly jano at oddkiddcreations
Right small update i got my self some new rims ( sorry for such bad pics)
it will sit abit higher when the konis are on
also picked up my two kenlowe fans there not very simline thos so might not be using them
and jano is sending my tps 3bar and the vac lines i need today with any luck SO the plan it to get the car finished and moved to mine
them when my ecu arives from jano i can plug and play hopefully
cheers.
#46
Hello,
Right so muz has been very busy with his on car so i decided to crack on with my solo i have been working on it the last two days i had muz check over eveyhting i have done and he seems happy with it so thats good
I have.
replaced the oil filter
replaced the fuel filter and re mounded it
re studded the back of the block
fitted the inlet and throttel body all with new gaskets
modded the rocker and fitted it
hide all the old wiring
fitted the cosssy rims
replaced the strut mounts
replaced the trottel cable
fitted the bonnet and bumper
and washed and waxed it
theres loads more but im shattered and cant be botherd to list it lol
well im going to prep the bay for paint either tonight or 2moro not sure yet, any way heres the pics.
got the tools out.
and the new stickers
cheers.
I have.
got the tools out.
cheers.
#49
Excellent update, lovin the new rims, u kept them quiet you dark horse lol.
Are you using a sandwich plate between your efi inlet and head? I offered mine up the other day and the port holes dont exactly line up perfecty plus the holes drilled for the studs or bolts are drilled too big, but guess i'll get round it.
#50
lol like to supprise poeple :P yeah i am using the conversion plate and i didnt have any problems linning it up, i take it you got your from jano 2 ? possobly a dodgy one and yeah you need to change the studs to shorter bolts apart fron the last stud on the pass side that stays the same.
hope this helps mate.
the bay is preped up for paint now nothing major tho atm because the engine is still in however it should clean up nice
#51
Well im reeallly stressiong out at th moment just got back from painting the bay and it came out ok considering how i done it. i found some rust that turned out alot worse tha i thaught and on top of that still no pectel board or parts jut want my bloody car back its got 2 months mot back an at this rate it wont be passing its next one my budget has already been blown through the roof so im HOPING that muz is going to come the the rescue with the welding but i dont excpect much since heha heped my out so much already
well i will upload some pics later .
pics
the bay looks ok really.
rust on pass foot well
rust on pass door
rust on pass chassie
its not too ba i suppose ? or altleast someone please tell me its not to bad
pics
rust on pass door
#53
Wye Valley Hardcore
Those sections will need more than that cut out for a proper repair as well. I'll have to take a look when I'm up next. Just paid the yearly rental on the bottle and filled it up that hurt.
#55
If you've got to do that rust Conor, which you have i'd just strip out all the interior and repaint the whole inside, would be mint then. That rust on the door hinge area isnt that bad is it mate?
#56
them areas arent that bad tbh just finding someone to do it if muz cant, on top of the the drivers sill needs doing and the fuse box area needs completly replacing, but i just want to bodge the car through its next mot then im going to completley strip the car at xmas and decide weather to reshell it or not.
#58
Small update, haven't been to the car for a while but i have had some nice new parts in the post and jano also told me he has got a pectel bored and will be sending my parts out next week
Fan ties and blue bullet connectors for the msd fan switch
i got some cable tidy to try and a cam cover ( only cost a tenner of ebay and is in mint condition with the bottom half and rubber gasket )
3bar ms bracket satin black
2 x stackable ignition amp brackets in satin black
maklor clamps
msd magnetic sump plug
new header ( gen ford ? )
grs evo 5 brand spanking new :P
Its been like xmas this week lol Not sure how I'm gunna fit 2 12" kenlowes on the front of that cooler ha.
Hopefully will get a parcel of jano next week with the rest of the parts in.
ecu
vac lines
fuel fitting
tps
3bar
Sorry its abit of a boring build but i will update more now as i am starting to get it finished.
maklor clamps
ecu
vac lines
fuel fitting
tps
3bar
#61
did a few bits and bobs tonight, there is no way im fitting 2 12" fans so im gunna have to use one.
fitted the ignition amps
relised the header was wrong
fited the lights and rad
thats about it getting there tho.
#63
alright chaps,
Haven't really bee keeping this to updated but ill give it ago now lol. well the car runs its been mapped and is running very nice indeed.
a few diffet parts.
p8 with anti,coil,water inj,air inj blah blah
grp A
also changed greens instead of the blues.
We got he car running on the Tues night ready for mappings at Janos weds, left at 6 broke down twice on the way due to the plugs getting so suety they wouldn't supply spark ,arrived at Janos 11.30 he set it up and mapped the car all day till half 6 only break we had was a quick run to Burton power for some proper spark plugs ( champ c57). we had the car running all day but due to no having a lamba connector on the car we couldn't check the boost so its been put down to 13 psi.
The car was nice and quick at 21 psi tho ha ha still pulls like a train now. only a few problems 1) phase senc was playing up a bit and we found out that it wasn't working so jano replaced it with anther untested one so we still didn't think it was working right but after he had a play it seemed OK, jano said something about the p8 being so sensitive that all the gaps/timming have to be exact .. and the only other problem we had was the water temp was abit high but as soon as you opened the bonnet it would drop drastically so Ive fitted some bonnet raisers and it seems t have helped even tho i think they look shit loll
So now the cars running hopefully get it to ford fair and than take it to Janos a few weeks later and get it up to the proper boost
a few diffet parts.
grp A
