What paint for underneath?
Old Sep 3, 2009 | 06:52 PM
pacwest's Avatar
pacwest
Puller of the Wrench
Default What paint for underneath?
I'm seeing lots of powdercoating on the moving bits. Excellent.
But what are you painting the body with? I don't need brand names, I mean what TYPE of paint?
I also see a lot of people removing the undercoating and then repainting. Are you using the same paint regardless of removing the goo or not?
Old Sep 3, 2009 | 07:44 PM
geordiesilverfoci's Avatar
geordiesilverfoci
Now body shops use waterbased paint then a solvent clear coat but solvent base coat is still available as the water base needs to be "blown" dry using air blowers,so a solvent base would be a lot easier to use but if its a solid colour,2k paint is better,this is a direct gloss,no clear coat required.
if removing underseal/stone chip id recomend recoating it with new stone chip before repainting for extra protection.
Lee
Old Sep 3, 2009 | 07:51 PM
pacwest's Avatar
pacwest
Brilliant answer, thx. But I was referring to what paint you are using underneath the car.
Old Sep 3, 2009 | 07:58 PM
geordiesilverfoci
The same underside as body panels.
Lee
Old Sep 3, 2009 | 08:10 PM
pacwest's Avatar
pacwest
I would think that base coat clear on the bottom would not be strong enough, but if painted over the undercoat it would be flexible enough is the right fles agent was added.
Thanks Geordie, it makes it very simple since I'm painting parts of the car the same white I just order some more and some more clear.
Old Sep 3, 2009 | 08:20 PM
geordiesilverfoci
No need to add any flex mate,just paint over the new stonechip/guard.
We have a spray sealer which is very good for stuff like this,made by 3m,looks like the original but when dries,dries like rubber so it is flexible enough and has no effect on the paint,eg. cracking.
You painting it white you say?
Old Sep 3, 2009 | 08:25 PM
pacwest's Avatar
pacwest
Yep, white 2wd saff and I want to do the entire underside, engine bay, slam panel, boot etc. while the motor is getting refreshed, then spray the whole car. Stock resto.
Old Sep 3, 2009 | 08:36 PM
geordiesilverfoci
i would do it 2k direct gloss,especialy the underside,2-3 coats,done,no need for clear coat.
Basecoat whites can be very deciving to paint.
Lee
Old Sep 3, 2009 | 08:42 PM
CosKev3's Avatar
CosKev3
I've used this on My Evo and 309 Gti underneath:
http://www.rust.co.uk/epoxy-mastic.cfm
Take a look at some of the stuff they use it on in there gallery.
Also comes highly recommended from classic car restorers.
If your doin a full underside job I would get some Dinitrol cavity wax off that same site above,much bettter than waxoyl for penetrating in box sections etc,alot easier to use aswell.
Old Sep 3, 2009 | 09:11 PM
EssexMikeSi's Avatar
EssexMikeSi
Good thread.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
