my swedish 3dr cosworth update 2 feb 2013
hello.
my name is micke, from sweden, nice cars you have over there!!!! here is some pics of my 3dr i have own since june year 2000, it was 100% original when i bought it but not for so long time. 439hp/498nm at 1,3bar.
pictures is from 2005-2008
here some more pics and info on swe http://www.garaget.org/?car=72259
Lucifer II - 666
Thats a sexy 3dr
thanks for all positive coments.
a pic how its look like for moment,not drive much this year bought a house last year soo..... whats going on this winter, a home made drysump system, the pump is from nascar from beginning, not finished, but verry son. Then a full new adjustable home built front and rear setup in cromollypipe and uniballs all over,just begin to built it,pictures comin when its built, hope save some kg whit a new in cromolly and 4x alu hubs from volvo s60r,a new wilwood pedal,new rear breaks,and alot more new parts allover the car. sorry for my bad english!!
some pics:
some pics:
it`s home modified azev a`s, 8 1/2x17" , i am lookin for monte`s 18" , the other are bbs splitt rims, alu/mag,also them home modified et and converted them to 4stud, and last 18" mo6
thanks
micke
bought some new things in the week, stack 8100, and a new serie from stack, electric boostguage, and a inovate LM-1 and my favourite ETAS lambdameter(rollsroys )
Stock car products dry sump pump - good choice. These US pumps are designed to oil and scavenge a chev so easily oil a cossie.
Some information I have on running one on a cossie may be useful to you. A friend runs a peterson pump on a cossie and actually drives it a 42% crank speed - he chose this by progressively lowering the pump speed until little oil was bypassing the pressure relief. No point in excessively heating the oil - however the peterson bypasses the oil of the relief valve to the scavenge side. The peterson is a gerotor style pump.
Another friend has a barnes pump which is a gear style pump like yours and settled on 50% crank speed.
Both guys installed a kinsler valve to relieve any positive pressure spikes to the dry sump tank. They tapped the block where the PCV valve normally goes to take this fitting -10 I think and then ran a hose back to the tank. Did not run a vacuum reg and pulled a neg vacuum at all revs.
Do you have a small turbo block or have you machined in oil squirters?
Also power steering can be done like this;
http://www.krcpower.com/ptoshaft.html
These pumps are designed for half crank. KSE also make one.
I´m not machined in oil squirters, modified the original oilpump a little bit, so i drive the oil backway through the old oilpump and out to original modified oil squirters. the beltwheel on the drysumpump now should be a smaller.
thanks.
micke
