Mk6 JWRC fiesta cosworth
Old 18-09-2015, 06:58 AM
  #4321
M K
M K's Avatar
Excellent guys
Thanks for the wiring info
Frayz - yes mate I'm doing snetterton on the 9th November, are you going as well?
Old 18-09-2015, 08:13 AM
  #4322
frayz
Boost Junkie
frayz's Avatar
Yeah I'm gonna take the Mini GP and see how it goes.
Tom kept nagging me to go
Old 18-09-2015, 08:18 AM
  #4323
COLEYST200
COLEYST200's Avatar
Originally Posted by markk
For what purpose? And only if you bypass the built in pressure switch.
I'm only saying wot my setup dose and my pressure switch brakes contact at about 500/600psi I'v not modded it in any way and . All MK is trying to do is make the system work as cheap as poss for the time been the same as my self as we don't have ŁŁ to burn . I no it's not the best set up but it gets it working
Old 18-09-2015, 07:50 PM
  #4324
M K
M K's Avatar
Took the car out earlier after checking about the attessa set up with Ian , thanks again mate
Anyway took it out with no attessa set up so full RWD and it was a bit of a handful lol
Leaving proper 11's down the road but steps out sharpish lol had some low speed fun as I feared I would run out of talent
Anyway the box sounds like shit lol, very noisy on over run and part throttle but goes into gear perfect so I suspect bearings but il look into getting a full rebuild soon
Old 18-09-2015, 08:18 PM
  #4325
Caddyshack
Caddyshack's Avatar
Not good to be noisey. It is amazing the difference with 2wd vs 4wd. I didn't think it would be that great. I take it that it is the box and not the clutch that is rattling? Mine def seemed to be clutch. If I have to rebuild mine then it will be a close ratio kit for sure.
Old 18-09-2015, 10:54 PM
  #4326
M K
M K's Avatar
Markk - what size aeroquip have you used for the attessa lines?
Going by original bore I was going to go AN10
Old 18-09-2015, 11:13 PM
  #4327
markk
markk's Avatar
Dash 6 from solenoid to cylinder, the hole in the cylinder is only around 5mm
Old 19-09-2015, 09:08 AM
  #4328
Caddyshack
Caddyshack's Avatar
Mate, I just cut the ends off each bit and walked in to pirtek, not long after I had all of the lines done, including the t piece to run the gauge that they supplied....if that helps?
I think I MAY have some of the low pressure side left as I bought spare, I will let you know if I have it as might be useful for sizing?
Old 19-09-2015, 12:20 PM
  #4329
ossie cossie
ossie cossie's Avatar
When I walked in to my local pirtek to get my pipes crimped I walked out with a lot less cash than I thought. Jesus they know how to charge.
Old 21-09-2015, 01:52 PM
  #4330
M K
M K's Avatar
I will be using aeroquip on the attesa lines, thanks for the offer though
Mounted the reservoir just now on a simple ally bracket nothing flash
Plan is to mount the attesa pump under the passenger seat as there is no room under the car for it, and this will keep all lines nice and short too
Just need to check it will clear the underneath of the seat
Old 21-09-2015, 02:31 PM
  #4331
Caddyshack
Caddyshack's Avatar
Might be best to mount it so the bleed nipple is easy to get to and wont spill fluid in the car...maybe pipe it out under the car? I used anti vibration mounts as I didn't want too much noise but then mine is a road car.
Old 21-09-2015, 02:48 PM
  #4332
M K
M K's Avatar
For how often it would need to be bled it would be just as quick to remove the passenger seat as its only 4 bolts plus you want the bleed nipples facing upwards
I will also use some kind of anti vibration mounting
ossie cossie (22-09-2015)
Old 21-09-2015, 05:14 PM
  #4333
COLEYST200
COLEYST200's Avatar
A bit hard to see but all my pump setup is just behind the divers seat
Old 21-09-2015, 05:43 PM
  #4334
M K
M K's Avatar
Almost bang on to how I'm mounting mine but passenger side for better weight distribution
Old 23-09-2015, 04:33 PM
  #4335
M K
M K's Avatar
Mounted the pump under the passenger seat and it just about fits although I'd need to remove seat to bleed it but that's only 5 mins so no real issue
Just clears seat
Also I finally decided to go for the Full Race ETS PRO
So ordered Friday night from Phoenix Arizona and it turned up Tuesday!!!
Get it all plumbed and wired in next but won't be for a little while yet, well the wiring anyway
Thanks
Marc
Old 23-09-2015, 06:33 PM
  #4336
smiley
smiley's Avatar
I'll wait until it's finished to pick the box up I want a passenger ride great stuff marc
Old 23-09-2015, 06:39 PM
  #4337
COLEYST200
COLEYST200's Avatar
Looking good under there . I'v got to get one of them controlers ASAP but I'v got uver stuff that I need to spend Ł on first like my new reg plate that's going on my focos 😊😊
And a new prop shaft
Old 23-09-2015, 11:17 PM
  #4338
M K
M K's Avatar
Smiley - too many old bill about on the roads for that, on track any time though
Ian - I just though ah sod it il buy 1 and test it out at brands hopefully
Old 24-09-2015, 05:58 AM
  #4339
ossie cossie
love your work.
Old 24-09-2015, 06:31 AM
  #4340
COLEYST200
COLEYST200's Avatar
I'm doing mallory park on the 10th of oct it's only down the road for me 👍
Old 24-09-2015, 07:10 AM
  #4341
smiley
smiley's Avatar
It's ok mate I've got diplomatic immunity honest aye id be happy with a look
Old 24-09-2015, 01:35 PM
  #4342
M K
M K's Avatar
Got the low pressure side sorted today and as I want to run center diff pressure on my dash display I also drilled and tapped the high pressure banjo bolt for a 1/8th npt thread for the sensor when I get it
Just the high pressure side to do then on to sort the wiring
Old 24-09-2015, 11:35 PM
  #4343
M K
M K's Avatar
Hi preassure side fittings will be here tomorrow so I can plumb the line into gearbox transfer case, photos once it's done of course
Old 25-09-2015, 02:01 PM
  #4344
ossie cossie
That,s a hell of a clean attessa pump, mine looks crap compared to that.
Did i see some where on one of these skyline box threads that someone put up the wiring diagram/ colour codes of the wires on the attessa pump the 6 pin connector.
Old 25-09-2015, 04:43 PM
  #4345
Caddyshack
Caddyshack's Avatar
I did. Just go to the ets pro site and it is all there under installation instruction pdf.
Old 26-09-2015, 12:51 AM
  #4346
ossie cossie
I think mine has 2 solenoids. 1 for 4x4 control and 1 for the LSD control. witch one do i use?
Old 26-09-2015, 07:29 AM
  #4347
COLEYST200
COLEYST200's Avatar
I don't no my self as never seen that tipe in the flesh graham C has got the same and I don't no if he sorted his yet
Old 26-09-2015, 07:56 AM
  #4348
andy888
andy888's Avatar
love the work. awesome.
Old 26-09-2015, 01:15 PM
  #4349
ossie cossie
here is my rusty one. with 2 solenoids,
Old 26-09-2015, 04:06 PM
  #4350
Caddyshack
Caddyshack's Avatar
I think the ets site has an answer for that. I will have a look.
Old 26-09-2015, 04:28 PM
  #4351
M K
M K's Avatar
That is an R33 pump
The second solenoid is a fail safe one, it can be wired with the ets pro no problem it just needs 12v I think to disable it so the pump only runs from the primary solenoid
Old 26-09-2015, 05:04 PM
  #4352
M K
M K's Avatar
Got my new 4 port boost solenoid ready to swap over from air injectors
2.8psi waste gate spring
Got the gearbox high pressure line to chassis done too
Old 01-10-2015, 05:53 PM
  #4353
M K
M K's Avatar
High pressure side plumbed in
Old 01-10-2015, 08:47 PM
  #4354
Fudgey
Baby Cheesus
Fudgey's Avatar
Almost there
Old 02-10-2015, 10:32 PM
  #4355
M K
M K's Avatar
Only a small thing but due to exhaust tunnel I put in the handheld fire extinguisher no longer fits tucked under the passenger seat so although not as tucked away it's a top priority for me to have it accessible if ever needed so I mounted it long ways and will make a new foot plate as well
More room than it looks still, worst case scenario passenger might knock the catch but no real dramas
Old 03-10-2015, 06:56 AM
  #4356
Minirotty
Lucifer II - 666
Minirotty's Avatar
looking good pal
Old 03-10-2015, 09:07 AM
  #4357
M K
M K's Avatar
Cheers mate
Old 09-10-2015, 05:52 PM
  #4358
M K
M K's Avatar
Cool
Done a few little bits
Painted and lightened some brackets
Made up an extra panel to attach to side of dash display for center diff control
Old 09-10-2015, 06:13 PM
  #4359
M K
M K's Avatar
New 4 way boost solenoid fitted
New an3 lines run for all boost
  #4360
Caddyshack
Caddyshack's Avatar
Wow, that bracket looks soooo cool. Holes are just great!
Quick Reply: Mk6 JWRC fiesta cosworth
