Mk6 JWRC fiesta cosworth
Old 17-07-2015, 10:56 AM
  #4041
M K
M K's Avatar
Drive by wire linkage and sensor bolted up, labelled, terminated and safety locked
Old 17-07-2015, 10:58 AM
  #4042
M K
M K's Avatar
Thanks for the kind words
Old 17-07-2015, 10:59 AM
  #4043
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Nice one
Its taken you long enough
Old 18-07-2015, 03:42 PM
  #4044
M K
M K's Avatar
Fitted an egt probe ready for when the car is getting fully set up
Sensor protruding to centre of housing
Fitted and ready for use
Old 18-07-2015, 05:25 PM
  #4045
NIMRODS_RST
MISSING MY RST!!
NIMRODS_RST's Avatar
All I can say is WOW I have followed this project from the start including your previous project XRT and the attention to detail in both projects is second to none, Fair play. is the Fast Ford mag out now??
Old 18-07-2015, 07:51 PM
  #4046
RobbieBambino
RobbieBambino's Avatar
Got my copy today, was a good read and pics looked great!
Old 18-07-2015, 08:16 PM
  #4047
rs clint
insane
rs clint's Avatar
Originally Posted by sgracing
Should be proud looks great ....
Just tuck that silly strap in
beautiful
Old 18-07-2015, 08:44 PM
  #4048
M K
M K's Avatar
Cheers guys
Had to repair a damaged thread to cylinder head for thermostat housing that was previously helicoiled and came out so wanted it done properly this time,
Bought a pukka time sett kit from WURTH for about Ł80 and now it has a good as new thread insert
New throttle body fitted and some pics of loom mods for egt/dbw/acc plugs
Will hopefully run it back up tomorrow to bleed coolant system through, can't be driven as DBW needs fully calibrating in Ecu but will tick over ok for what I need to check
Old 18-07-2015, 11:23 PM
  #4049
M K
M K's Avatar
Had the steering wheel buttons re done as the old plate was always tempory and was just a bent up piece of steel, it was ok but not symmetrical lol and it obstructed the view of the warning lights of the dash2 display so had to be changed,
Old set up
New set up
Much better
Old 19-07-2015, 01:25 AM
  #4050
M K
M K's Avatar
Pedal sensor and linkage all re fitted
Engine loom all back in and converted to dbw
Old 19-07-2015, 09:58 AM
  #4051
PaulinhoT
PaulinhoT's Avatar
I've been following this thread for a long time now, also I really enjoyed the article in "said" Ford magazine
Also loving these updates, truly this is working art and well done.
Old 19-07-2015, 10:36 AM
  #4052
M K
M K's Avatar
Thank you mate
Glad you like it and are enjoying the updates
Old 19-07-2015, 08:21 PM
  #4053
Seen your feature matey..stunning car. You wanna be proud of yourself owning this.
Old 19-07-2015, 08:25 PM
  #4054
M K
M K's Avatar
Thanks Glenn
Old 19-07-2015, 08:48 PM
  #4055
Caddyshack
Caddyshack's Avatar
I got the mag yesterday, looks excellent, the pics really show the detail.
Old 19-07-2015, 09:30 PM
  #4056
Focosmitch's Avatar
Exactly what i plan to do with the buttons on the wheel
Old 20-07-2015, 11:10 AM
  #4057
Caddyshack
Caddyshack's Avatar
Is there a reason why you chose a GT3076 over a Borg Warner? When my car had an air leak on the inlet manifold it idled at 3000 rpm, if you shut off the engine you could hear the Turbo still spinning for quite a while afterwards.
Will you actually race this car or just Track Days?
Old 20-07-2015, 11:21 AM
  #4058
M K
M K's Avatar
Hi Toby
I bought my turbo about 2 or 3 years ago and the new BW were not around then, would maybe like to try one in the future though with a twin scroll manifold
For the first year it will most likely be just track days but at some point I'd like to do a bit of sprinting or hill climb, when I'm comfortable in the car and have the diffs and box sorted for the launches lol
Old 20-07-2015, 03:30 PM
  #4059
Caddyshack
Caddyshack's Avatar
Originally Posted by M K
Hi Toby
Makes sense, I think the BW would make it easier to drive as it would be more linear but the low down torque does give the boxes a hard time.
When you out in the skyline box it may be worth buying some shock proof gear oil from opie.
Old 20-07-2015, 05:03 PM
  #4060
M K
M K's Avatar
Yeah will Deffo be using the shockproof oil mate
Old 24-07-2015, 12:19 PM
  #4061
chodjinn
chodjinn's Avatar
Been following this thread for years and never posted, it's brilliant to see it finished and running. Possibly one of the best builds I have even seen mate, congratulations.
Old 24-07-2015, 12:32 PM
  #4062
M K
M K's Avatar
Thanks mate
Old 24-07-2015, 12:36 PM
  #4063
Focosmitch's Avatar
Hi marc could you please let me know the part number or exactly what tb for the dbw your using? Going the same route with mine..
Old 24-07-2015, 06:35 PM
  #4064
Tev
Tev's Avatar
this may sound like a stupid question but what are the advantages of going over to a drive by wire system??
cheers jay
  #4065
Caddyshack
Caddyshack's Avatar
I have been looking at r34 boxes, they are smaller than r33, lighter, much stronger ( can take 1000 bhp), close ratio and 6 speed. They are 3 times the price but probably worth it. I might ask MK if he can do the bellhousing.
Old 24-07-2015, 07:26 PM
  #4066
Caddyshack
Caddyshack's Avatar
cheers jay
You can map the response I.e small pedal large opening plus great for traction control, aggressive throttle maps or more sluggish....like a sport button on a modern car.
Old 25-07-2015, 09:16 PM
  #4067
M K
M K's Avatar
Hi Toby
The r34 are good as you say but the cheapest I have seen a good working 1 is Ł3250 second hand so your nearly in PDE box territory and rebuilds are expensive on the skyline box if ever needed
I'm gonna stick with r32/33 and then next upgrade would be oppliger sequential for me but doubt il ever save that much for a gearbox
xr2wishy (02-08-2015)
Old 25-07-2015, 09:20 PM
  #4068
M K
M K's Avatar
Wrapped the turbo/wastegate downpipe today
Will be doing some of the exhaust too but will need more wrap so won't do that just yet,
Also fitted the front extinguisher lines and nozzles, I couldn't easily mount them from the front looking back so have covered fuel rail and turbo from the back/firewall, the angle of the nozzle is enough to cover what's needed from the mounting locations
Old 25-07-2015, 09:32 PM
  #4069
M K
M K's Avatar
Also staked the front hub nuts and marked them along with the spacer nuts
And made another speed sensor bracket as last one was not sturdy enough and the magnetic pick up was too small, will paint bracket once I know it's all working ok
Other jobs done today,
Drained all oil ready to fill with new 10w50 millers nano drive when it arrives Monday or Tuesday, and fitted a new ford oil filter,
Secured door handles to interior door cards as they have been resting in ace up until now,
And had to buy and fit and calibrate a new Ł200 ATL fuel sender as I killed the last 1 by accidentally putting 12v to the ground wire when testing a dash pin my own fault and an expensive lesson lol but all sorted now
Lots more to do before ford fair next weekend
Old 25-07-2015, 09:33 PM
  #4070
perryzetecpuma
perryzetecpuma's Avatar
One question, will I be seeing this at Ford Fair next weekend?! - I need to know so I can bring my tissues to clean up my mess after I've walked away! This car looks the f*cking nuts!!!!
Old 25-07-2015, 09:42 PM
  #4071
M K
M K's Avatar
Yes the car will be at fordfair on the FastFord stand and hopefully out on track too
Old 25-07-2015, 09:44 PM
  #4072
perryzetecpuma
FastFord stand?! Lucky you! I want my Puma to be there one day! What time track you got booked? I mean 400bhp in a Puma is a lot but it will be nothing against you so I'll just wave you past if you're on at the same time as us
Old 25-07-2015, 10:07 PM
  #4073
M K
M K's Avatar
Other part of exhaust wrapped with what was left
Old 25-07-2015, 10:08 PM
  #4074
M K
M K's Avatar
Not 100% sure what time...... About 12 and 4 I think but would have to check,
Il be going easy mate as its my first time out in the car so will have nothing to prove on track, just be well grinning driving it around
Old 25-07-2015, 10:31 PM
  #4075
perryzetecpuma
Same as us really, the car isn't even finished yet and I don't think it will be fuly tuned so will only have 220+ ish power which should still be good fun in a little puma. Looking forward to seeing your car though and hopefully I'll get some decent pictures and be able to post them up here if you don't mind?
Old 25-07-2015, 10:36 PM
  #4076
M K
M K's Avatar
Sounds like a good track toy mate
Yeah put any pictures up you want
Old 25-07-2015, 10:39 PM
  #4077
M K
M K's Avatar
Re done the drivers side arch liner as the other 1 was too big and would of needed fastners to keep secure and stop it from catching the wheel and ripping out, decided to make smaller to only cover the open top section, much better now and no fastners or cable ties needed as tension holds it in place securely
Need to wait for more of the plastic sheet before I can do passenger side as I used all I had re doing this 1 but glad I done it
Old 26-07-2015, 09:09 PM
  #4078
binks101
binks101's Avatar
Just spent the last couple of hours reading this thread and without a dought it's the best one yet!!! Wickid car Wickid work! Top job can't wait to see it at ford fair
Old 27-07-2015, 07:58 AM
  #4079
tbtstt
tbtstt's Avatar
With all the fine details you keep adding, the car almost looks too good to use! Absolutely stunning build, I have yet to pick up a copy of this months Fast Ford magazine: best get my finger out before next months comes out!
Old 27-07-2015, 05:37 PM
  #4080
Caddyshack
Caddyshack's Avatar
What is the read locking / marking fluid that you use called?
Quick Reply: Mk6 JWRC fiesta cosworth
