endo's xr4x4
Old 14-07-2008, 07:09 PM
endoxr4x4
endoxr4x4's Avatar
Default endo's xr4x4
Heres some pics of my car when i first got it and after some modification and a lot of cleaning. Its now used daily and for show's.
spec is as follows-
2933cc v6 engine running superchipped ecu with k&n filter in drilled airbox or twin cone filter's,stainless two box exhaust,poly engine mounts,spax shocks and springs which lower 50mm,polyurethane bushes all round,cosworth anti-roll bar(compression struts and adjustable tca's to be re-fitted),polished alloy front strut brace,rear strut brace,wolfrace 7x17 white alloy's with federal 215/40x17 tyres.
when first got car February 2005
july 2006 after a quick resto and 3.1 fitted
capesthorne hall first show may 2007
tatton park june 2007
augsut 2007 3.1 removed origanl 2.9 refitted
3.1
2.9 awaiting refurb
after refurb
rear end refurb
rear end re-fitted
back together
day after mot and on show at capesthorne hall august 2007
september 2007 cholmondeley castle
port sunlight september 2007
crich tramway 2007 with mates 2.8 turbo 4be
weston park first show of 2008
cholmondeley castle 2008
capesthorne hall 2008
haven't done anymore show's as missed a couple due to work commitments and weather but have got some booked in august
Old 14-07-2008, 08:24 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Good work, what was the reason for refitting the 2.9? keep it standard?
Old 14-07-2008, 08:27 PM
col cos1
col cos1's Avatar
love xr4x4`s i want another 2.9i twin turbo,loved my old one
Old 14-07-2008, 08:33 PM
endoxr4x4
endoxr4x4's Avatar
3.1 had oil pump problem and wasn't as good as supposed to be and engine matches the chassis plate again. i'd love to twin turbo mine but fuel is bad enough as it is
Old 14-07-2008, 08:36 PM
vroooom ptssssh
It Wasnt Me!
Ah I see! fair enough.
Ever thought of the 24V conversion?
Old 14-07-2008, 09:01 PM
endoxr4x4
endoxr4x4's Avatar
yer have thought about them but need to do timing chain's on them before fitting or disaster and big time expense plus can't buy the bits to do them as most were only available from ford but ain't no more and whether to go for a boa or bob as both have prob's and most say use the boa with the bob inlet and cam's as bob wiring is a bit tricky. have thought of twin turbo and aftermarket management or throttle bodies and management but all comes down to cost. going for big brake conversion and coilovers with eccentric top mounts first then sort the engine out as may start doing track days aswell as shows.
72*Tina
01-09-2015 10:06 PM
Jimboxr4x4
11
07-05-2005 06:19 PM
GavinPearson
21-09-2004 09:17 PM
Graceland
15-04-2004 09:08 PM
Quick Reply: endo's xr4x4
