Ag motorsport carbon focus cossie **** bhp time attack sept 2013
#450
Originally Posted by Gatecrasher
10" on the front you mental fooker Love it
when you hoping to be on track andy?
its the front they need 10's to reduce the understeer it gets bad towards the end of a race thats why im trying to get it lighter so they don't heat up as much and moving the engine back to take the load off the front
#453
Not welcome...
where you racing up near you?
Pretty Extreme building a whole new car to sort out an under steer problem but i suppose if i had the money and know how i would be doing the same
do you think it will feel very heavy on the steering with 10" fronts
Either way im sure the cars going to handle fantastically and go like a fooking rocket now its so light
#456
i'm only building a new one cause sold the old one for good money and may aswell make this one better
steering should be fine its getting a manual rack with an electric colum that you can adjust the how light you want it
#460
Originally Posted by andrewg
Outstanding work on the car as always, I'll give you a bell a bit later this afternoon....
#461
#462
Originally Posted by 34CHASSIS
HI WHY DONT YOU PUT SWAGE LINES IN YOUR PANELS,IT WOULD STOP ALL THAT WARPING AND WOULD LOOK LOADS BETTER
#463
#464
i reckon she thinks that seat has shrunk cause she used to fit in it
#466
Not welcome...
Good luck at KH
#467
Good luck at KH
its from a new corsa and you send the control unit away and comes back wired with a variable resistor
#468
Gatecrasher - search for Corsa EPAS on ebay.
I paid Ł50 for the one going in my escort but they usually sell for around the Ł100 mark.
Box of tricks with adjuster is usually around Ł100 too.
If you have money to burn though just buy the same thing but new off Demon Thieves for about Ł1500 + vat and plus box of tricks
Andrewg - Awesome work once again, 10 " wide fronts !! The whole build is very impressive
#471
YOU CAN PUT SWAGE LINES IN WITH A BENDER
#472
#473
thats what i'm talking about need to invest in one of them
#478
Good luck at KH
#479
Me thinks the driver might cause some controversy at scrutineering!
Awesome progress, take it you're not going to manage the test day on the 2nd March Andrew ?
