RS1600i turbo, to be reborn
Old 20-01-2008, 12:59 PM
  #521
DazC
DazC's Avatar
Originally Posted by RS16iDale
dazc yes mate miss it but its good to see its gone to a excellent home.
ive got a new project now a mk1 xr2 with a rst lump
It's had it's head kicked in for the last 1500 miles and it's not missed a beat!
Old 20-01-2008, 01:37 PM
  #522
DazC
DazC's Avatar
Originally Posted by G2RSR
Originally Posted by paprst
You will not have fuel problems,
your fuel setup is ok (great injectors and management).
The problem is the air flow.
The mix on the outer cylinders would have less air and more fuel
despite your larger throttle body.
With the standard Escort manifold ,which has the throttle body in the middle of port 2 and 3 that means that 1 and 4 clyinders suffer a per cent loss of air flow.Having reached that kind of power levels your outer cyls will suffer.This air flow loss will do a great damage to your engine.
Since you have recently rebuilt your engine (using quality pistons),i think that it's a pity.
I would advice you to use the EFi setup {efi inlet+adaptor plate if needed} (combines economy with efficiency) or a larger custom made inlet.
Who told you that jano oddkidd thats exactly the way he words it but usually its to make you to convert to his Efi cosworth managment
LOL!!
Old 21-01-2008, 09:24 AM
  #523
maxrs16
maxrs16's Avatar
LOL!!
jano is correct about the inlet on the MFi escort. It WILL suffer loses to the outer two cly with std low boost, what happens if you raise the boost?
Every bit of advise i have ever read or heard from jano has been correct so maybe before you try knocking him you would talk to him in person!
Also jano NEVER forces people to buy or to convert, if you knew him first hand Daz you wouldnt laugh
Old 21-01-2008, 06:19 PM
  #524
AJC
PassionFord Gold Member (Male)
AJC's Avatar
G2RSR
thank you very much
maxrs16
daz did not say it, he just 'lolled'
Old 21-01-2008, 09:34 PM
  #525
DazC
DazC's Avatar
LOL!!
I'm not bothered about what Jano says mate. I know for a fact that the EFI manifold is even worse than the standard manifold but that is what I know to be fact. But you know, if Jano says I am wrong then I can't be correct can I? For he is Jano, the ultimate tuner.
I was laughing about what G2RSR said.
Old 22-01-2008, 07:03 AM
  #526
originalcabbie
originalcabbie's Avatar
LOL!!
After looking at all the options myself when converting to Cosworth mangement, I fimrly believe which ever manifold is used you will get a certain % loss of air flow through one or twon cylinders.
If you use the standard brick manifold as above 1 & 4 may suffer, if you use a 16i or XR3i inlet, like Christian, may get a loss through 1 & 2, if you use a EFI manifold you may get a loss through 1 & 4 again. But the power output of Christians engine, proves that any loss has no detrimental effect.
The ultimate answer is to look at power output and detonation rates of cars running high power CVH engines with different inlets. I agree there is going to be a % loss, but the manifold is pressurised prior to the air being let into the engine, therefore one would assume that all cylinders are at equal pressure.
Personally, I prefer the personal touch and if you are willing to spend the time to modify the manifold and make it look very factory then I praise you.
Me personally, I am gonna do something similar to Christian and I am going to use a 16i manifold. I like the look, plus I can return my S1 back to standard afterwards using the stock manifold.
Old 22-01-2008, 05:02 PM
  #527
AJC
AJC's Avatar
im going to design my own tricky custom inlet that will allow equl air to each cylinder
Old 22-01-2008, 11:06 PM
  #528
mitchrst
1981
mitchrst's Avatar
LOL!!
fuck jano off and start thinking for yourself i have tested the manifolds on a flowbench there is slight diffrence to the outer cylinders on mfi on the manifold 1cfm and the s1 manifold flows more air than the s2 item
Old 23-01-2008, 08:54 PM
  #529
DazC
DazC's Avatar
Mitch,
It would be good if you could try an EFI one on a flow bench too. I'd like to know some exact figures on the differences between 1/4 and 2/3 as the throttle body is directly opposite to the inlet runners for 2/3 where 1/4 are off to 1 side.
It's good to see that some people are investigating what items are better and learning for themselves rather than just believing what ever they are told.
AJC,
It can be done but it's not straight forwards and it's not viable to fit it under the bonnet of a Mk3/4 Escort!
Old 23-01-2008, 09:47 PM
  #530
AJC
AJC's Avatar
daz, im fabrication king
anything is possible
Old 26-01-2008, 06:19 PM
  #531
DazC
DazC's Avatar
It's got
Old 27-01-2008, 06:28 PM
  #532
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Top work, looks great what shade of red is it painted?
Old 27-01-2008, 08:11 PM
  #533
DazC
DazC's Avatar
Sunburst Dave. Standard colour.
Currently running a held 20 dropping to 18 psi. Will be increase tomorrow evening a little!!
Old 02-02-2008, 09:27 AM
  #534
maxrs16
maxrs16's Avatar
So you saying you "know for a fact" is rubbish as you aint tested it yourself anyways. Just regirgitating others pub talk aint ya
The flow test has already been done by Jano with the figures and proof.
So you carry on talking what you know to be "fact" and let people prove you wrong. Then when you dont agree with the facts you can call them names and contradict yourself to them, people can carry on laughing at you
You are the weakest link, goodbye.
Old 02-02-2008, 03:27 PM
  #535
DazC
DazC's Avatar
Whatever you want to believe mate. It is pretty obvious there will be a deficit of air to the outer 2 cylinders on the EFI inlet compared to the standard one just be studying it and thinking logically. Ever thought about individual cylinder AFR and EGT readings to determine flow imbalances? No, thought not. Flow benches are not the only way.
I have never seen Jano prove anything he has ever claimed as yet so take your pub talk opinion and fuck off out of this thread. Unless he is capable of bending the laws of physics.
If the EFI has an imbalance of less than 6% across the inlet runners I will appologise.
Until then, you stick to paying someone to do your tuning and I'll carry on trying things for myself and learning things first hand.
Old 02-02-2008, 04:05 PM
  #536
homer j
homer j's Avatar
to be honest i've heard several conflicting views on this subject and i can't see how the standard escort plenum causes the outer cylinders to run on less air. as far as i can tell the plenum is pressurized anyway under boost and air will only flow down the inlet runners when the valves are open. the space is not large enough to cause air velocities to slow down to the point where airflow loss is a major problem. the proof is in the pudding though. just look at the NMS cars running on series 1 inlets with over 300bhp. if what has been said is true then these engines wouldn't last five seconds at high revs yet ollie and tim both put in outstanding top speed runs at the PF daddy thrash in 2007. think logically and it just doesn't make sense to say that the S1 and S2 inlets will potentially cause the outer cylinders to fail. just my 2 pence worth on the subject.
Old 03-02-2008, 10:15 AM
  #537
maxrs16
maxrs16's Avatar
Logically...pmsl.
Stop thinking about things and talk to people who HAVE tested it and DOES have proof.
Old 03-02-2008, 10:27 AM
  #538
AJC
AJC's Avatar
ive got an idea, make your own thread on it, instead of cluttering up this one
Old 03-02-2008, 11:33 AM
  #539
DazC
DazC's Avatar
Logically...pmsl.
Please, extract your head out of Jano's arse.
Yes logically. To sit and study a design and to spot obvious flaws in it before you start testing. It helps with understanding your findings once you have tested it.
Thats the difference. I am out testing things while you are talking to people who tell you what they want you to hear.
If Jano has tested it, you should be able to prove to me that the EFI inlet has less of an imbalance that the standard unit then. As my AFR readings indicate otherwise.
I'll tell you what, I'll stick to my job in software, electrical and mechanical engineering and you can stick to what ever job you do.
Old 03-02-2008, 11:37 AM
  #540
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
It's got
Won't that clog up the injectors?!
I Like boooosst
Old 03-02-2008, 11:43 AM
  #541
DazC
DazC's Avatar
It had 40psi the other night for a brief moment!!
Old 03-02-2008, 11:48 AM
  #542
Charlie Chalk
Unknown.
Old 03-02-2008, 01:27 PM
  #543
Gadget
Spanner monkey
Gadget's Avatar
loving it, what a proper looking car! nice project!
Old 04-02-2008, 04:46 PM
  #544
AJC
AJC's Avatar
Charlie Chalk
it was more like this for me
det det det det
Old 05-02-2008, 07:16 PM
  #545
01010101011011
01010101011011's Avatar
Personally, trying to go down the cosworth route, im not impressed with Jano, after waiting for weeks for his paypal email to sort out cash for the bits, I got frustrated and decided on another management system ,a hell of a lot cheaper and standalone for me to learn how to map.
Personally, its your preference on what manifold you want to run.
Old 05-02-2008, 08:58 PM
  #546
NEEDFORSPEED
NEEDFORSPEED's Avatar
ive got an efi manifold in the shed you can buy if you want andy
Old 07-02-2008, 02:44 AM
  #547
AD-RS1600i
AD-RS1600i's Avatar
Stunning car, very well done
Enjoy
Old 12-02-2008, 04:29 PM
  #548
AJC
AJC's Avatar
thank you
Old 12-02-2008, 04:36 PM
  #549
andysrs
andysrs's Avatar
Got to love this 16i
Old 12-02-2008, 04:37 PM
  #550
AJC
AJC's Avatar
thank you andy
Old 13-02-2008, 10:02 PM
  #551
smitsturbo
smitsturbo's Avatar
aright mate, i see you had escort cossie alloys for sale & was wondering if you tried them on your rs16i & if they touched your coilovers?
cheers
Old 13-02-2008, 10:13 PM
  #552
DazC
DazC's Avatar
I don't think he tried them on the 16i to be honest although I might be wrong.
Old 23-02-2008, 03:21 PM
  #553
Canada1
Canada1's Avatar
Awesome build.
I am interested in the cylinder head work done.
Were stainless valves used?
Was there any flow testing done?
I am assembling a new cylinder head now, and am not sure if standard valves are reliable, or if a switch to stainless is a wise move.
Old 25-02-2008, 03:58 PM
  #554
AJC
AJC's Avatar
the head is a stage 3 NMS head, big valves on inlet and exhaust and ported
double valve springs, newman cam and solid lifters
Old 27-02-2008, 09:33 AM
  #555
AJC
AJC's Avatar
just orderred a GRS frontt mout as the pro alloy one aint up to the job
Old 27-02-2008, 10:12 AM
  #556
carlo
carlo's Avatar
I thought pro alloy were good
Old 27-02-2008, 10:58 AM
  #557
AJC
AJC's Avatar
they are, the workmanship and quality are superb
its just not big enough for 32 psi
Old 27-02-2008, 11:09 AM
  #558
rs shawn
S1 Database Editor
rs shawn's Avatar
Looks great Andy.
you've done a cracking job on this
Old 27-02-2008, 02:38 PM
  #559
AJC
AJC's Avatar
Talking
cheers shawn
new rear arms fitted
ready for an ARB
Old 27-02-2008, 03:13 PM
  #560
fezzajsy
fezzajsy's Avatar
looks awesome
Quick Reply: RS1600i turbo, to be reborn
