RS1600i turbo, to be reborn
#482
Yes, that is what he thinks. If you look at the EFI inlet and compare it to an Escort inlet, the 2 inlet runners on the EFI inlet are directly opposite the throttle body. The Escort manifold has the inlet runners away from the throttle body so they can't be force fed air as easily
#486
a bloke i work with would prefer that pic to be the other way round with the tractor in the foreground, he collects tractors.
looking good mate but... i prefer the standard rs16i wheels too
#489
The theory of the different wheels is to try and increase traction as currently it wheels spins quite easily. Ultimately he would like to leave the car on 7 spokes but it's a bit lively when coming on boost.
#508
Originally Posted by boothy
what does the air to air injector do mate ??????
#509
Why can't the spots be fitted Andy???
What size are the comps?
#513
i reckon keep the comps, gives that car a different but good look to it. also being the 5 spokes the suit the old skool image of the car i jsut think the colour is all wrong.
and they give the car the stance that it needs!!
#514
Originally Posted by RS16iDale
the spots cant be fitted because the front panel has been cut out for a intercooler,this was like it unfortuantly wen i brought it.
looks wicked tho mate
#515
#517
Bodybuilding
Location: Cannot be identified by the information given.
Originally Posted by paprst
You will not have fuel problems,
your fuel setup is ok (great injectors and management).
The problem is the air flow.
The mix on the outer cylinders would have less air and more fuel
despite your larger throttle body.
With the standard Escort manifold ,which has the throttle body in the middle of port 2 and 3 that means that 1 and 4 clyinders suffer a per cent loss of air flow.Having reached that kind of power levels your outer cyls will suffer.This air flow loss will do a great damage to your engine.
Since you have recently rebuilt your engine (using quality pistons),i think that it's a pity.
I would advice you to use the EFi setup {efi inlet+adaptor plate if needed} (combines economy with efficiency) or a larger custom made inlet.
Who told you that jano oddkidd thats exactly the way he words it but usually its to make you to convert to his Efi cosworth managment
