Peugeot 205 with 4wd cosworth engine and running gear.
Old 23-08-2017, 07:33 PM
  #1641
rooos
rooos's Avatar
...no doubt about that too...
keep us posted
Old 23-08-2017, 08:16 PM
  #1642
Caddyshack
Caddyshack's Avatar
Thanks Guys. I hope to keep the progress reports coming - these things are never finished as they were not production cars.
Old 26-08-2017, 12:00 PM
  #1643
Caddyshack
Caddyshack's Avatar
I just tried the car with a change from full soft on the rear ARB to 1/4 turn harder and I am amazed how much more darty the front felt and much less roll on the back, once I have the spring rates roughly right I will get Jonfoc to look at the rear Shox and then over to gravity force or Dave wedge
Old 26-08-2017, 12:04 PM
  #1644
jonfoc
jonfoc's Avatar
Sounds good mate. I'm going bladed on mine. I'm back in at Leda next month so I can get a wriggle on when you're ready.
Old 26-08-2017, 12:10 PM
  #1645
Caddyshack
Caddyshack's Avatar
Oh cool, will def get them over this time then, still don't have corner weights though but at lease we could get the current design copied.
Old 26-08-2017, 12:23 PM
  #1646
jonfoc
jonfoc's Avatar
Yes mate. I'll let you know when I'm in. I'll draw them up and get the ball rolling. Then when you get weights we can valve accordingly
Caddyshack (26-08-2017)
Old 10-09-2017, 05:29 PM
  #1647
Caddyshack
Caddyshack's Avatar
I saw this and thought it applied to a few of us on here.
Adam-M (10-09-2017)
Old 10-09-2017, 05:34 PM
  #1648
jonfoc
jonfoc's Avatar
Quality!
Old 11-09-2017, 09:32 PM
  #1649
stu21t
stu21t's Avatar
That's me to a tee
Old 29-09-2017, 07:42 AM
  #1650
Caddyshack
Caddyshack's Avatar
I sent my old cam cover off to Mark at MK to do a cam trigger mod so I can ditch the distributor, I will now send the cover off to Mick at Spraystation to do a full refurb in red before fitting. You can see the plug for the dizzy, the bolts for the coil packs and he welded up a bodged breather (deleted the old hole) and fitted a new one in a better place.
New breather and cam trigger
Coil pack bolts on to head of bolt that holds down the cam cover
These are the bolts for the cam cover, Mark also makes them for the other height of coil pack, neat idea
Here you can see the top where you put the bolt in to secure the coil pack
Old 29-09-2017, 03:51 PM
  #1651
c20tbo
c20tbo's Avatar
What the cost on those bolt/spacers Toby, I could do with some for my turbo danger
Old 29-09-2017, 04:49 PM
  #1652
Caddyshack
Caddyshack's Avatar
I actually don't know as I paid for bits as a whole. I know he made a set for me and then had to start again as I needed shorter as my turrets where the coil pack needed to be made shorter so he probably has a set of 4 left over. They are stainless steel.
Old 30-09-2017, 08:21 AM
  #1653
COLEYST200
COLEYST200's Avatar
Looking good Toby . So when You pulling the dizzy out and cutting it in half and also the cam shaft and putting it on you lathe to fit the trigger ?
Old 30-09-2017, 08:53 AM
  #1654
Caddyshack
Caddyshack's Avatar
Hi mate, I am thinking I will get the cam cover refurbed first and then find out if Mark Shead will want to finish the job off and remap the car as it needs an update for the intercooler, hart inlet and exhaust mods. I will either send the bits to MK to do unless Mark has a source, I don't fancy doing those bits myself.
Old 20-11-2017, 05:44 PM
  #1655
Caddyshack
Caddyshack's Avatar
The editor of PPC practical performance mag got in touch saying they want to do an article on my car which is nice, I will give them the max power mag with it in and see if they will do a sort of homage to that.
Old 21-11-2017, 04:28 PM
  #1656
moondustka
Boooost!
moondustka's Avatar
Sounds good
Caddyshack (21-11-2017)
Old 28-11-2017, 07:27 PM
  #1657
Caddyshack
Caddyshack's Avatar
Just tried out a 215/45/16 Yokohama track tyre on my 8x16 et28 new rims, they fit and fill the arches well but look a little too big, I am now trying a 205/45/16 on same rim....all this experimentation gets expensive with special order tyres but my local tyre shop is looking after me.
Old 30-11-2017, 07:01 PM
  #1658
moondustka
Boooost!
moondustka's Avatar
I used to fit 215/40/16s
Might be worth a try? I know you could do with all the grip you can get?!
Old 30-11-2017, 07:34 PM
  #1659
Caddyshack
Caddyshack's Avatar
I have struggled to find 215/40, just trying a 205/45. It amazes me how you can see the larger diameter over 195/45, I know it should being 45%of 10 cm but it is very obvious.
Old 30-11-2017, 09:49 PM
  #1660
Ridgey
Ridgey's Avatar
If it was 45% of 10cm it would be obvious Toby
The reality is 4.5 mm is less than normal tyre wear depth
Old 01-12-2017, 02:33 PM
  #1661
Caddyshack
Caddyshack's Avatar
Ha, I got that a bit wrong eh? Of course it is mm not cm.
Old 28-12-2017, 04:18 PM
  #1662
Caddyshack
Caddyshack's Avatar
Today I made a start on the electric conversion for the power steering. I need more space between the radiator and engine to add a second fan as in the summer the little 205 radiator with one little fan struggled when I was in traffic and I want to make sure the cooling is fool proof, especially if I add more power.
I am using a saxo / 106 pug unit as it is small ish and doesn't weigh any more than the Ford pump and bracket. I made up an anti vinbration mount to mount it to the inner wing above the chassis leg.
After removing the pas pump I can now see loads of room for the extra fan, I may even get a thicker rad in there, spoox motorsport make a 60mm one with slimline fans, if that fits I will be very happy.
Tomorrow I will whizz in to pirtek and get them to make me up the pressure hose.
Long term I will need a bespoke reservoir bottle.
Old 28-12-2017, 05:21 PM
  #1663
Caddyshack
Caddyshack's Avatar
I don't think I have room under the dash for the electric system, the 205 is tiny under there....it has crossed my mind many times though OR just go for a manual rack, most of the early 205s didn't have power steering and mine doesn't weigh that much more but does have a bit wider rubber.
Old 28-12-2017, 06:18 PM
  #1664
Caddyshack
Caddyshack's Avatar
Yes Mark, that might happen along with Wrc top mounts on the front.
Old 28-12-2017, 06:53 PM
  #1665
Caddyshack
Caddyshack's Avatar
With a full cage it would be ready to race I suspect.
Old 28-12-2017, 07:27 PM
  #1666
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Post some pictures as you go a long I’m considering it on mine. But looking at the size of the pumps I’d probably go a class
Old 28-12-2017, 08:25 PM
  #1667
Caddyshack
Caddyshack's Avatar
Wil do, a class is more upright but same size overall/
Old 29-12-2017, 01:14 PM
  #1668
Caddyshack
Caddyshack's Avatar
Just got back from pirtek where they made me up new hoses and silver soldered on to the cossie ends, Ł90 all done for both...happy with that. Will do some pics later
Old 29-12-2017, 04:06 PM
  #1669
ajamesc
ajamesc's Avatar
Pirtek are good we use them a fair bit at work if we need hydraulic pipes made up
Old 29-12-2017, 09:24 PM
  #1670
Caddyshack
Caddyshack's Avatar
Really interesting blokes and superb equipment, I was there an hour and met 4 other petrolheads, one had a 500bhp rs4
Old 30-12-2017, 12:31 PM
  #1671
Caddyshack
Caddyshack's Avatar
Made these brackets to hold the pump to the car with an anti vibration bung in between
Trial fitted for space but I need to move the reservoir
This is the pirtek pressure side
Bracket I made bolts on to the motor using the bolts that hold the motor to the pump
Another angle of the bracket on the pump
Anti vibration bit in place and wrapped the pump in rubber. When this bolts to the car it all lines up square.
Old 30-12-2017, 12:37 PM
  #1672
markk
markk's Avatar
These pumps work fine on cars with narrow tyres. As long as you move the steering slowly and don't expect too fast a reaction time you will be fine.
Had one on mine to try and was not fast enough when you ask for a quick direction change.
Caddyshack (30-12-2017)
Old 30-12-2017, 12:43 PM
  #1673
M K
M K's Avatar
For normal road and track driving you should be fine mate,
Mark will be doing alot more steering inputs on loose surface rally than we ever will
I have done a few track days and loads of road stuff on mine with the same type pump and 8x18 wheels with no issues
Old 30-12-2017, 12:45 PM
  #1674
Caddyshack
Caddyshack's Avatar
Thanks, my 205 only runs 215 rubber which is not that much wider than a saxo vts at 195 so it would only be down to the rack being different. I will soon see if it works or not.
Old 30-12-2017, 12:53 PM
  #1675
M K
M K's Avatar
my tyres are 235/40/18 mate and ive had no issue track or road
Old 30-12-2017, 02:48 PM
  #1676
Caddyshack
Caddyshack's Avatar
Moved the reservoir back so had to weld up a 90 degree bend so made a simple mount off the 90 to hold it to the bulkhead.
It’s at an angle in the pic as the jar is jacked up on one side.
Reservoir on 90 and then back to supply the pump
Pressure and return both on and all now pointing in same direction and tight
Old 30-12-2017, 02:55 PM
  #1677
Caddyshack
Caddyshack's Avatar
Just the wiring to sort and then fill it, bleed it and see if it works.
If all is ok then I can measure up for the extra cooling fan.
Old 30-12-2017, 04:44 PM
  #1678
M K
M K's Avatar
They need some hefty gauge wire as think they have a 40amp relay
Old 30-12-2017, 04:48 PM
  #1679
Caddyshack
Caddyshack's Avatar
That's useful to know as I was going to order a 30 amp relay, will bump that up and get a 40 amp setup then.
Old 30-12-2017, 04:53 PM
  #1680
markk
markk's Avatar
Needs a 70a relay and a 40 fuse.
Quick Reply: Peugeot 205 with 4wd cosworth engine and running gear.
