ST170 Turbo Engine Rebuild - CGI - thinking of selling up!!
#121
Thats awesome, let me know how that comes out. Would you be interested in making another CF middle plate for c.o.p.'s ? if so I'd be interested...
Also what brand/part # are your cops? I'm looking to run it on megasquirt. This is going to be interesting for me as no one has run megasquirt on my car model (ford escort zx2 , U.S. car)
#122
also forgot to post your vct delete: https://zxtuner.com/displayProductDo...&categoryId=17
and also your obx header, make sure to make a reinforcement from the header flange to the turbo flange, there cracking them here in the u.s. because the welds are weak.
#123
The link you have given above is not for a focus SVT hence why I went the route of having one mached up myself.
To be honest I'm now having a set of custom billet cams made which removes the need for a spacer altogether.
Most tubular manifolds will crack when you have a 10kg + turbo hanging off 12"+ of cherry red hot tube and vibrating like mad at 7000+rpm.
In the past I have used an old valve spring welded to a support bar to support the weight of the turbo and to allow the primaries expand with the heat. It works well
Manifold will be similar to the above design but slightly different
#124
Indeed its always worried me about having a manifold which puts the turbo over near the battery tray in the mk3 fiesta but i want one anyway and im hoping i can sort some bracing for it.
Loving everything you have done so far mate.
#125
svt focus intake vct and contour/zx2 exhaust vct use the same vct cam gear. The adapter works for both.
Which exhaust mani are you getting then?
good luck!
p.s. keep the pics coming, I like seeing whats going on!
good luck!
#126
I'm having to get a new clutch set up hence I have to sell what I already have
http://boardroom.wscc.co.uk/cgi-bin/...ST;f=8;t=48473
#129
Originally Posted by bassboy
What is the ST170 the equivilant of in the states? ZX2 or SVT? or am i completely wrong LOL
bassboy
bassboy
Car is making progress.
Stripped the car down to chasis and in the process of lightening everything completely.
Carbon panels, carbon seats, titanium bolts etc etc.
Reckon I can take 50kg out the car if I try hard enough and get it to 500kg or below
Valves have come from the States and head is getting done as we speak
New prop and diff are here
will update pics when I get time
#130
Amazing project. Any further progress? I am interested in the charge cooler, can you give me some ruff measurments for it? Also what size radiator and pump will you be using for it?
#131
where did u get the Metallwheels for the timing belt?
Or are they selfmade, if they do you have a sketch?
mine is also geting to this step end.
carbon fiber in work...
Cheers Mark
Cheers Mark
#132
You can get dimensions of the PWR charge cooler range from there website.
As for the pulley wheels there a bit of a hybrid I have used from another model and adapted them to fit.
CGI block has finally come so it is currently being machined and bored.
Will post up pics soon
#133
After last years engine I've got a bit carried away with the new engine.
Got everything I need now, just in the build stage
Spec is as follows
Head
ST170 head, extensively ported with 3 angle valve seats. (flows 183.1 cfm inlet at 10" water)
Ferrea Custom 31mm Numonic exhaust valves with single groove stems (28mm standard)
Ferrea 34.5mm 214N inlet valves with single groove stems(33.5mm standard)
Variable intake timing selenoid removed and blanked
Piper Double valves springs with custom spring platforms
Ferrea titanium retainers for a Mazda 626
Ferrea collets for Nissan Skyline
Trojan Valve guides custom made by TTV
Vauxhall XE valve stem oil seals
Magnetti Marrelli Coil on Plug system
Denso ITV spark plugs
Modified thermostat housing
Billet Cat Cams custom ground, aggresive profiles
CFM Alloy pulleys
Bottom end
Focus WRC Compacted Graphite Iron Block from Cosworth bored to 86mm
Pro Gram Billet main caps 1045 steel
ARP bolts throughout
Kolben Schmidt sputter bearings, main and big end
CP custom forged pistons low comp
Farndon H Section Forged Steel con rods 144mm c/c
Farndon 80mm stroke custom crank (standard is 88mm)
Modified Focus RS water pump
Pace 3 stage dry sump system with custom pump assembly
Engine is 1858 cc and has a rod ratio of 1.8
Boost
321 stainless steel 1.75" ID exhaust manifold
GT3076HTA or GT35 turbo with Tial v band exhaust housing
44mm Tial wastegate
50mm Tial Dump Valve
PWR Chargecooler 6"x 8"
Pro Alloy 12" x 18" chargecooler Rad
Bosch High Flow chargecooler pump
Inlet
48mm Jenvey ITB
4 x 80lb Seimens Deka injectors (3 bar)
Fuelab mini fuel pressure reg
Inlet system from Jenvey using off the shelf parts
Jenvey Plenum and base plate
Bosch 044 fuel pump with -8 lines
Transmission
TTV lightweight 3kg steel flywheel
Quaife Sequential Gearbox with alloy casing
7.5 Cosworth Diff with Quaife ATB shot peened and super finished CWP
Superclutch 7.25" twin paddle sintered plates
Heavy duty Lightened prop with rubber doughnut
Also removed about 40kg from the car since last year
This is the first time that Fardon or anyone else for that matter have made a destroked crank for the Zetec at the time I ordered it in December as I shopped around
Will post up pics as it starts to come together
Spec is as follows
Head
CFM Alloy pulleys
Bottom end
Boost
44mm Tial wastegate
Inlet
48mm Jenvey ITB
Transmission
#136
Originally Posted by Captain Mike
Bloody hell Austin thats some spec, i want to see this,
Is Dennis having anything to do with it ??
Mike
Mike
Dennis doesn't know much about turbo's or Zetecs IMO
Duncan has rebuilt my box and diff though
#138
I wont go any further on that Austin are you going to dyno it on his dyno though or go through to Harvey ??
Would look to catch up and take a look at it some stage mate when i'm up your next of the woods next, who knows maybe drop down for some clay shooting as well
Mike
Mike
#139
Originally Posted by 18"chris
looking good
any ideas when i may see this playing with bikes again along gunness straight
#143
have i just seen a yellow westfield outside my house?is it finished,sounded very nice
any mo updates?
any mo updates?
#144
any mo updates?
any mo updates?
#147
Not in a major rush to get it done as I've got loads of other stuff on the go at the moment
Also recently bought a couple of 5 cylinder volvo engines I'm going to go mad with.
One turbo'd and one nasp
Will come along to a meet when its done.
The ST170 is the same as the Focus SVT
#148
Very nice car Austen.
What kind of turbomanifold did you have on the car during Ten of the best 2006?
And how did you like it?
I will build an engine with hopefully 400-450 bhp.
cheeRS Christian
cheeRS Christian
#149
Got mine from here:
http://www.chevroletls1.com/zetecturbo.html
Fitted well and made the turbo spool up quick but for ultimate power the design is not the best.
You need to use a T3 flange on your turbo with this type of manifold
Should manage your figure with an external gate attached to manifold
I had a 38mm take off welded to the side of the manifold which worked well for the external gate.
#150
Thanks Austen.
I am after fast response rather than a high bhp figure.
So think i might go for this one as it is a cast unit for long life instead of a welded manifold, i see its also possible to get it with a flange on the top and on the bottom, might be easier with the wastegate fitted this way. How wold you think it would work with the wastegate mounted this way?
cheeRS Christian
cheeRS Christian
#151
try using one of these instead
similar money
http://<br /> http://cgi.ebay.com/e...spagenameZWDVW
If you go with the cast one i would mount the wastegate on the side rather than the bottom to assist flow, but it all depends what room you have.
similar money
#153
Originally Posted by AustenW
New Chargecooler came this morning
PWR chargecooler from Australia
This size has been used on 900bhp Evo's running 9's
I should just be able to make it fit in the engine bay
Mark
#154
Hi Mark
Yes I've herd that too about the Norris Car, and realise he went back to an IC setup.
I'll be running alot less boost and power than that though
The problem is that I have no room to put an intercooler of any real size that would be man enough for 500bhp plus
It would need to be the same size if not bigger than an RS500 style cooler which is impossible under my nose cone
My last chargecooler set up was based around a Pace 3 core unit as used in the escort RST kits. These are supposed to be bad according to everyone on here but I actually think it work fantasticly after looking at the logging. I used to get temps of 10 deg c above ambient which I was very happy with when giving it abuse.
If stood in trafic it did suffer from heat soak though
With a chargecooler setup eveything has to be spot on or you will get problems like the standard Pace kits suffer from, (small pumps, prerads and pipework)
I'm using a large Bosch water pump, 19mm pipework and the largest prerad possible I can fit under the nose cone which I have also ducted in to force the air through it.
I know its a trade off but the best I can do with the space I've got
I have a friend who has used one of these before on a decent setup and he reported good charge temps from the logging on long blats out and track days off the logging
If I get charge temps to the same as before on a little more boost I'll be happy so fingeres crossed.
