Escort mk2 rs2000 project
Looking to swap my rs2000 it needs quite a bit of work which I can't do at the moment, it's red 1977 r reg, earlier broadstripe shell, it needs wing rails, outer sills rear arches, rear tank and wheel wells, front floor pans could be repaired or replaced depends how fussy you are, the roof pillars where they join the rear 1/4's need repaired too iv cut the driver side one out and have repair panels for both sides, also drivers inner sill has a very small hole 10p size so easy repaired, door skins will also need repaired or replaced and wee patch needed on the roof, it's not a weekend job but will be well worth doing and you have an rs, it's missing its engine and box too so that's also needed, I'm looking to swap it for another mk2 2 door that's doesn't need as much done to it doesn't have to be sporty model just any 2 door will do, my rs comes with log book and vin plates too.
This is a picture I got before I bought my car it's now sitting in a thin coat of primer but will need sanded back and painted after its had its repairs done, I know I'm maybe asking a lot to get a swap for a car not needing much welding when mine needs a lot but hopefully there will be someone out there that would like a genuine rs, the rs is 30 miles south of Glasgow and will need collected as I don't have a trailor cheers.
