cossie 2wd for 4x4 rear bearing carriers
29-12-2012, 02:56 PM
Pick-up P100 Power!
As above, anyone want to swap a pair off 2wd rear bearing carriers for a set of 4x4?
05-01-2013, 07:38 PM
Live long and prosper!!
Thought they were the same
05-01-2013, 07:45 PM
Fixing Fords
Me too, it's just the callipers differ, one solid 3dr and one vented 4x4 cos and Granada cos.
05-01-2013, 09:29 PM
Me too. Only the none cossie sierra's have a different type
06-01-2013, 07:01 PM
Pick-up P100 Power!
Thanks, i was sure they where different
Joffy has done me proud again then as i have some 2wd ones!
06-01-2013, 07:09 PM
ah just thought is it a xr 4x4 diff?
if so the only difference is they use 253mm solid discs and the cossies are 273mm in either solid or vented
06-01-2013, 07:39 PM
Resident Wrestling Legend
all cossie variants of sierra and escort (and granada for that matter) use the same rear hubs and are all interchangable, be they 2 or 4wd
everything else uses the same normal hubs
all the cossie variants use a 273mm diameter disc (10mm thick or 20mm thick if it's vented)
everything else uses a 253mm diameter disc, again 10mm thick or 20mm thick if vented (on the granada estates)
06-01-2013, 07:52 PM
Really granada estate vented? thats a new one on me
06-01-2013, 07:53 PM
yup, look it up, had more than a few calipers off of them in the past
06-01-2013, 07:55 PM
best keep that quite eh
06-01-2013, 07:57 PM
Pick-up P100 Power!
Yep, much cheaper than buying cossie calipers even though they are the same
Different height in the carriers, that i know
though 4x4 and 2wd where different
09-10-2015 07:38 PM
FlashRS
14-09-2015 12:36 PM
RsS2daz
14-08-2015 05:26 AM
track.focus'd
12-08-2015 05:53 PM
Old ford
31-07-2015 06:50 AM
