Other Marques Use this section for any non Ford marques.
Toyota Carina
Old 11-08-2018, 01:18 PM
  #121
PaulinhoT
PaulinhoT's Avatar
I replaced them with some Yokohama tyres, and some Pro Race alloys.
Old 11-08-2018, 01:20 PM
  #122
PaulinhoT
PaulinhoT's Avatar
Old 12-08-2018, 10:31 PM
  #123
The Black Count
The Black Count's Avatar
A vast improvement, although thinking about it during the day I feel the car just does not deserve them. Put the old stuff back on and take it to the festival of the unexceptional next year and spend the money and modify some thing else, the st170?
Will keep looking to see what you do next, its your car to do what you want with it and have fun
PaulinhoT (13-08-2018)
Old 13-08-2018, 04:05 PM
  #124
PaulinhoT
PaulinhoT's Avatar
I think once I begin work on the planned 2L engine, well things should start to seem a little different. First off I want to get the car to stop, steer and go around corners as it's like being at sea at the moment lol.
Old 19-08-2018, 03:48 PM
  #125
visa_broke
visa_broke's Avatar
I'm looking forward to seeing this progress, its still a fun project.
You might want to get the tracking checked if it has done that to the original tyres save wearing out the yoko's as they are not the longest lasting tyres you can get.
17 inch tyres you should hopefully get something like a 330+mm disk underneath which will fill them out. Have a look at getting a spare upright and then look and see if you can get uprated calipers off the usual suspects, porsche, merc, some alfa's, evo's. Keep the costs down while you are able to fab up some (or if the bolt pattern is correct you might get lucky and find some bolt on's)
PaulinhoT (19-08-2018)
Old 19-08-2018, 07:07 PM
  #126
PaulinhoT
PaulinhoT's Avatar
That's all brilliant advice, thank you, I'll do that
Old 28-08-2018, 05:47 PM
  #127
PaulinhoT
PaulinhoT's Avatar
Just a small update, as I'm ultra busy at work at the moment, which is great as it's more money for car parts.
Old 04-09-2018, 03:09 PM
  #128
PaulinhoT
PaulinhoT's Avatar
I've been messing with the car again.. up-rated my headlight bulbs and done a few other bits.
Old 04-09-2018, 03:15 PM
  #129
PaulinhoT
PaulinhoT's Avatar
I also gave the grill, door bumps guards and wing mirrors a lick of paint, as I wanted to see what it would look like before I commit on getting the bumpers and bits done by a professional.
Old 05-09-2018, 07:31 PM
  #130
PaulinhoT
PaulinhoT's Avatar
New video is up.
Old 05-09-2018, 09:25 PM
  #131
The Black Count
That's a lot of paint, how much are you using?
Going to look better once its all white
You sound like HubNut at times, if you have not seen him on You Tube then you should.
Old 06-09-2018, 09:10 AM
  #132
PaulinhoT
PaulinhoT's Avatar
Agreed, I may of over estimated the amount of paint I needed lol but it should keep for a while, and I may use some of it for a lower lip if I choose to go that way. So far I've used one can of primer, and the same in white, top coat, so yes, a few are left lol.
I've just checked out HubNut, thanks for the heads up, I will spend some time watching them lol
Old 15-09-2018, 02:12 PM
  #133
PaulinhoT
PaulinhoT's Avatar
Old 22-09-2018, 01:42 PM
  #134
PaulinhoT
PaulinhoT's Avatar
I took the Carina out for a drive this morning, just to enjoy it, and despite it raining, well I enjoyed myself. It also helped to get the old mind ticking, as I need to work out my next lot of modifications for the car.I did stop and take a few photos of the car in the rain, using my rather out dated mobile phone.
Old 23-09-2018, 03:22 PM
  #135
3i Jim
3i Jim's Avatar
Looking good. Coilovers and painted bumpers will set it off.
PaulinhoT (24-09-2018)
Old 24-09-2018, 03:05 PM
  #136
PaulinhoT
PaulinhoT's Avatar
Cheers, in talks with both things on your list
Old 01-10-2018, 02:35 PM
  #137
PaulinhoT
PaulinhoT's Avatar
Not much of an update as I'm waiting on a few parts to show up, so here's some photos of my adventures today.
Old 01-10-2018, 05:54 PM
  #138
PaulinhoT
PaulinhoT's Avatar
Old 02-10-2018, 04:01 PM
  #139
PaulinhoT
PaulinhoT's Avatar
Well today my "ebay" headrest phone clamp arrived, it was between Ł5 and Ł6, so a bit of a bargain. I'll post up the first video I did with it in a little bit.
Old 02-10-2018, 04:02 PM
  #140
PaulinhoT
PaulinhoT's Avatar
So here's my first video, using my old mobile phone, and the clamp did okay. I'm going to work out a way to solid mount it, to remove the slight movement it has, but for the price, it's not bad.
Old 09-10-2018, 06:14 PM
  #141
PaulinhoT
PaulinhoT's Avatar
A little update today, I had both lower balls joints changed on my car, as one was mentioned on the MOT, so I thought, keep it balanced.
My suspension turned up, and fingers crossed on it fitting okay.
Old 13-10-2018, 03:30 PM
  #142
PaulinhoT
PaulinhoT's Avatar
An unboxing video
Old 17-10-2018, 04:59 PM
  #143
PaulinhoT
PaulinhoT's Avatar
Well a little update today, I've had my coil overs fitted, and the car already feels transformed. Now I will have to get them set up correctly, and get the car lowered a little.
Old 17-10-2018, 05:11 PM
  #144
Caddyshack
Caddyshack's Avatar
Enjoying this thread, Looks good. Brake fluid looks like it needs a swap and then a proper fill up in the pics.
PaulinhoT (18-10-2018)
Old 18-10-2018, 09:35 PM
  #145
PaulinhoT
PaulinhoT's Avatar
Agreed, brakes are on the list, and I will take a look at the fluid tomorrow (Friday), thanks.
Old 18-10-2018, 09:39 PM
  #146
PaulinhoT
PaulinhoT's Avatar
Well I managed to spend a little time today playing with the settings on my coilovers, and I've set the front of the car a little lower to try and level the car off. The handling of the car has genuinely been transformed.I've yet to check out the camber settings on the front, which is my next objective, but also to enjoy it a little, and sort out the slight rub on the rear.
Old 18-10-2018, 09:40 PM
  #147
PaulinhoT
PaulinhoT's Avatar
Oh I quickly put together this video.
Old 20-10-2018, 03:10 PM
  #148
PaulinhoT
PaulinhoT's Avatar
Well I was up and out early this morning testing and adjusting my suspension, I only have my phone to take pictures and videos on, so here's a few I took.
Old 20-10-2018, 03:12 PM
  #149
PaulinhoT
PaulinhoT's Avatar
The Carina has actually been lowered about 1 1/2 inches, but I now need to roll the arches to take it down that little bit more. Here's a video I took, and yes you can hear the rub lol..
Old 20-10-2018, 07:22 PM
  #150
PaulinhoT
PaulinhoT's Avatar
Oh go on then, two in one day
Old 27-10-2018, 10:36 PM
  #151
PaulinhoT
PaulinhoT's Avatar
New video up today folks..
Old 03-11-2018, 04:34 PM
  #152
PaulinhoT
PaulinhoT's Avatar
Paid a visit to Shell Bay near Studland today, although it was very windy.
Old 03-11-2018, 09:33 PM
  #153
PaulinhoT
PaulinhoT's Avatar
Made a little driving video today.
Old 04-11-2018, 09:24 PM
  #154
PaulinhoT
PaulinhoT's Avatar
Here's the other part of that video, thanks for watching.
Old 10-11-2018, 12:30 PM
  #155
PaulinhoT
PaulinhoT's Avatar
As I was in work early the other morning, I thought I would take a few quick photos of the Carina E. Doesn't she look brilliant.
Old 10-11-2018, 10:36 PM
  #156
PaulinhoT
PaulinhoT's Avatar
New video is up.
Old 11-11-2018, 08:40 PM
  #157
PaulinhoT
PaulinhoT's Avatar
New video up tonight.
Old 11-11-2018, 08:55 PM
  #158
PaulinhoT
PaulinhoT's Avatar
Still trying to work out how to do 1/2 the stuff on YouTube, but I'm working on a promo advert for the channel
Old 12-11-2018, 04:29 PM
  #159
PaulinhoT
PaulinhoT's Avatar
Another day another video.
Old 12-11-2018, 07:44 PM
  #160
PaulinhoT
PaulinhoT's Avatar
I've just uploaded another video, more driving.
Quick Reply: Toyota Carina
