Mondeo V6 calliper identification
I'm having trouble getting a replacement calliper as none of the motor factors around here seem to know what it is. The calliper in the pics is from a 1998 V6 mondeo, it has a 60mm diameter piston and is used for the 278mm discs. I have heard that some cosworth callipers are the same? Any help with more accurate identification would be greatly appreciated.
Cheers in advance
Alan
[/url]
Cheers in advance
Alan
[/url]
Later V6s had the Zetec calipers, even tho the discs are larger. You can tell if you have the Zetec calipers by looking at yours discs.. If there's a 5mm or so area of your disc that appears to be unused.. closest to the hub, then you have the Zetec calipers.
Typical Ford... mean with brakes.
wowk
30-03-2021 07:49 PM
