Other Marques Use this section for any non Ford marques.
Mk6 Escort GTI thinking of buying one?
Old 24-02-2006, 05:22 PM
Robliddle
Robliddle's Avatar
Default Mk6 Escort GTI thinking of buying one?
Any one got a mk 6 Escort GTI, Thinking of buying one ,just wondered what they were like on performance and what to look out for when buying one!
Old 24-02-2006, 07:55 PM
Chrissy_bwoy
Chrissy_bwoy's Avatar
performance is OK, nowt mind blowing
not too old so usual things to look for, service history etc, no real rust problems except round the base of the spoiler as its a water trap
Old 27-02-2006, 07:24 PM
Paddy
Legend
Paddy's Avatar
Depending on your age for insurance, you may as well just get an Si.
The GTI is just an Si with 5 spoke wheels and side sills..... [tho many more Gti's have optional half leather]
Engines are 115 ish bhp?
Look out for rust, rust and more rust plus those engines suffer from potentiometer problems so make sure it idles ok from cold, when its warm and revs freely enough
Old 02-03-2006, 08:10 PM
silencer
silencer's Avatar
i got a mk 6 si its good nuff performance wise do 130 n sixty in around 10 altho neva timed it got that damn icv prob (how anoying) but part from that good nufgf place to start a projet dont really need to do much to em to make them look better.
Old 06-03-2006, 02:32 PM
ScORTED
Project Money Pit
ScORTED's Avatar
all 95 onwards 1.8 zetec escorts have the exact same engine, get a 1.8 lx, much cheaper then add the stick on bits if you like that sort of thing or use the 2k you'll save making it go faster
Old 12-03-2006, 03:11 PM
fiestasi1800
fiestasi1800's Avatar
All the gti's had half leather as standard didn't they?
Anyway, I had a 3 door one in black and loved it. As said, the performance isn't great but not too bad. Depends what car your upgrading from I suppose.
The only problem I had on it was the fuse box. Water must of been getting into it somehow and fried it. Cost about Ł240 from ford for a new one.
Old 12-03-2006, 09:27 PM
Chrissy_bwoy
all half leather yeah
and the fusebox prob was probably a leaky windscreen seal had one on mine cause a few probs
Old 16-03-2006, 10:05 PM
SiV6Si
SiV6Si's Avatar
No leaky wind screen, if you look where your ford fitted alarm horn is ( just under the bonnet on the left hand side ) you will notice two holes, they sit DIRECTLY above the fuse box and water gets in thru there, common problem with the MK 5's but not so bad on the MK 6's
Old 09-04-2006, 08:49 AM
mattxr3i
mattxr3i's Avatar
gti : wouldnt bother - i looked into it as well, as said the performance is like any other 1.8 zetec apart from 130 spec xr3i. The insurance is stupidly high, the same as an st24 and the st24 wouldnt even need to try to beat the gti!
As said get the si as it has the smae performance, 5 insurance groups lower, and add the half leather seats and sill extensions and you are there
Rs_Motion
Escort MK 5 / MK 6
07-01-2016 10:38 PM
Vincereese
18-08-2015 03:57 PM
Mark RS
14
11-08-2015 11:45 AM
Quick Reply: Mk6 Escort GTI thinking of buying one?
