1.6 Focus knocking from top end - PassionFord - Ford Focus, Escort & RS Forum Discussion
General NON CAR Related Discussion. To discuss anything that is NOT related to cars at all but wouldnt be classified as a post suitable for any of our other forum catagories.
Old 17-05-2018, 05:09 PM   #1
bigdel
bigdel's Avatar
Default 1.6 Focus knocking from top end
Went to look at a Focus last night as a run around for my son while his FRS is off the road
it was a 52 plate 1.6 Zetec up for £200
Bodywork was ok but the engine has a really loud knock which seems to be coming from the top end somewhere.
it drives ok and when under load is relatively quiet but when revved it rattles like a bag of nails.
thought about taking a chance and making an offer on it but walked away from it in the end
any idea what it could be?
doesn't sound like little ends but maybe camshaft or a sticky cam follower?
it was a 1.6 Zetec SE engine if that makes a difference
bigdel is offline   Reply With Quote
Old 19-05-2018, 05:23 PM   #2
H3lsing
ffoc.co.uk
H3lsing's Avatar
I would check the condition of the oil, and maybe change it if it's really old. Check the condition of spark plugs and they are all firing. Check the condition of the timing belt that it has all it's teeth and while your at it check the timing itself. I would get a compression test done.
The next thing you could try if your handy with some tools, is to remove the rocker cover and have a looksie, check if the inside of the cover isn't being fouled by anything. Also check the engine mounts as they can be misleading and make it sound like an engine problem. The manifold could be cracked or flexi pipe too.
Just a few things to consider, I wouldn't rule out some bigger problem such has the main bearings. If that is the case it wouldn't be worth time nor money putting right.
There are plenty other cars out there with an up to date MOT for not much more than you paid. It might be worth more from the scrap value.
Edit: I just re read your post and see you have walked away from it , good idea. I certainly wouldnt' entertain anything without an MOT at least. It sounds like you got lucky this time.
H3lsing is offline   Reply With Quote
Old 19-05-2018, 06:27 PM   #3
gcfcos
gcfcos's Avatar
These 1.6 focus are dreadful, seen so many pack up over the years, seemed to be the engines were the worst of the focus range
gcfcos is offline   Reply With Quote
Old 19-05-2018, 07:32 PM   #4
bigdel
bigdel's Avatar
Seems like we made the right move then, cheers guys
Picked up a 53 plate 1.6 Civic with a year's mot on it for £250 today, has a little knock from the n/s corner which we think is a drop link, and given that there were two brand new ones in the boot ready to fit, I think we're right. Even if it's something more serious, my lad works for Honda, so should be relatively inexpensive to sort
Old 19-05-2018, 09:04 PM   #5
gcfcos
gcfcos's Avatar
That's great mate can't beat a Honda for reliability
Old 19-05-2018, 09:46 PM   #6
studabear
studabear's Avatar
Quote:
I've killed plenty off on MOT for burning oil, but not heard many with major rattles. Even when they come in with no oil they are normally nice and quiet.
studabear is online now   Reply With Quote
zetec s silver top knocking top end? tomnuth8 Technical help Q & A 5 06-11-2009 01:58 PM
Top end knocking sound S2Steve Ford Escort RS Turbo 17 03-04-2008 05:18 PM
Top end knocking noise ? Richie Russ Ford Escort RS Cosworth 5 19-09-2005 07:59 PM
zetec top end knocking Chrissy_bwoy General Car Related Discussion. 8 27-12-2004 10:05 PM
TOP GEAR, TOP GEAR, BBC2 NOW, TOP GEAR, TOP GEAR TOP GEAR !! Ginge ! General Car Related Discussion. 16 15-11-2004 11:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
