View Poll Results: What FWD Ford do you own and modify?
Voters: 64. You may not vote on this poll
Poll for FWD peeps
Poll for FWD peeps
Right then , I'm looking to see what the most tuned FWD fords are so that I start looking into a traction helper, for startline grip and power out of the bends
Also please give me feed back on power output.
Football Cwazy
turboboss on here runs a very high powered FRST and i believe he uses fully rosejointed zoo bottom arms and probably a few other trick bits and bobs, pm him
Football Cwazy
Danny, good to hear your looking into making something up for us who have FWD.
Just what i need. My escort needs something badly! If ya come up with something i'll defo be up for buying it from ya.
Originally Posted by timrud
Danny I hope your going to look into more than Fords
I'm just about to rose joint my Corsa..
Thanks For the responds guys,
just finding my feet
Originally Posted by zippyobrien
please make something to give me traction,
no grip till 3rd in the dry
no grip in any thing in the wet.
please make us escort boys ( i mean the car not proffesion) some toys
then learn how to drive
The tyre advice etc ya gave me with the Bf Drag radials broke the clutch and gear box and ripped the mounts so the traction was mint lol.
You makin a kit for track or pod ? would be hard to suit both i recon,
Hope its a success pal.
Tim
i run link arms etc and adj tcs etc .
Happy xmas,hope u have a success full 2006 pal.
Tim
Tim
Tim
Glad my advise worked shame about the box and clutch though, this is going to be a problem for I many I feel.
Hopefully we can come up for something for track and Pod, will need settings altered etc but I aim to use the same hardware.
Good to Meet you finally earlier Danny.
already spent a while scraping the shit off the inside of my car !
thats after I run out of Petrol on the way back from yours ! and I had no credit ! lol
Can only vote for one car Ive got an FRST, 2 ERST'2 and a Focus RS but most interested in parts for the FRST. Current stats are 12.78 1/4, 0-60 4.9, 0-100 9.5 running on Yoko Advan's 195-50-15's at 14 psi. Been looking at running a 205-50-15 on the front. Any recommendations fro a road legal and also a nice sticky strip only tyre?
I reckon develop something for the FRS, it wont be long before a large number of them are above 400 Brake IMO
THEN the new Focus ...
Then the S1 / S2 .. If Ford based...
bfgoodridge drag radials you need to have some side wall so 50 profile or higher
And also I'm going to be doing a promotion on the new Avon ZZR road legal track day tyre in early 2006
with regards to Ford only work, I'll work on ANY type of car and I'm willing to try anything new with regards customers own ideas, the only thing I ask from a customer is that there end result is to GO FAST!!!
Sorry for my bignorance but i ait entirely sure what products you make?????
I am presuming alsorts of fabrication work such as bottom arms, cages strut braces etc
I have a nova sr and am possibly after a bolt in cage and both front and rear strut braces, could you drop us a pm if you do this sort of work cheers
400BHP Focus, was a 1.8 115BHP Family focus
Engine
2.0 Zetec Engine
JE Forged Pistons
Arrow H Section Forged Con Rods
Piper Cams
Fully Ported Head & Shimming
GT3071-r Garrett Hybird Roller Bearing Turbo
Piper Vernier Pulleys
Simens 650cc Injectors
Compression Raation 8.2:1
Hayward & Scott Custome Manifold
Hayward & Scott Custome Duplex Exhaust
Quickshift Induction Kit
RS Radiator
RS Water Pump
RS Oil Pump
RS In Tank Fuel Pump
Pace Large Front Mouted Intercooler
Baily Cosworth Oil Breather
ST170 Spark Plugs
Aqua Mist Water Injection System
Baily Dump Valve
Omex 710 Managment System
Blitz Spec S Boost Controller
Alloy Piping
Silicone Hosing
3 Bar Map Sensor
Transmission
Custome Built MTx75 Gearbox
ATB Limited Slip Diff
Shot Ping & Polished Gearset With Extended Ratios
Custome AP Clutch
Brakes
AP 4-Pot Callipers & 330mm Drilled Disc's
ST170 Rear set-up with EBC Red stuff pads
Braded Lines
AP DOT 5.1 Fluid
Suspenshion
Lowered 35mm all round on custome Leda suspenshion
Rolling Roaded To 400+ BHP & 400+lb ft Torque At 1.6 Bar Boost
Designed & Built by www.powerengineering.co.uk and mapped by Chris Todd
Engine
2.0 Zetec Engine
JE Forged Pistons
Piper Cams
RS Radiator
RS Water Pump
RS Oil Pump
ST170 Spark Plugs
Baily Dump Valve
Alloy Piping
Silicone Hosing
3 Bar Map Sensor
Transmission
Custome AP Clutch
Brakes
Braded Lines
AP DOT 5.1 Fluid
Suspenshion
Engine
2.0 Zetec Engine
JE Forged Pistons
Piper Cams
RS Radiator
RS Water Pump
RS Oil Pump
ST170 Spark Plugs
Baily Dump Valve
Alloy Piping
Silicone Hosing
3 Bar Map Sensor
Transmission
Custome AP Clutch
Brakes
Braded Lines
AP DOT 5.1 Fluid
Suspenshion
Engine
2.0 Zetec Engine
JE Forged Pistons
Piper Cams
RS Radiator
RS Water Pump
RS Oil Pump
ST170 Spark Plugs
Baily Dump Valve
Alloy Piping
Silicone Hosing
3 Bar Map Sensor
Transmission
Custome AP Clutch
Brakes
Braded Lines
AP DOT 5.1 Fluid
Suspenshion
dont have a fwd beantin thing danny but id say the focus would prob be a good one to develop to start with
S1 with 400bhp.
Got Avo coilovers on the front, Bilstein coilovers on the rear, adjustable tca's , safety devices 6 point cage with door bars too. Was fully corner weighted and that made a hell of a difference
Will be looking for the other bits to make it handle well and help put the power down with more grip.
Very interested in what you come up with Danny
Originally Posted by gus
look forward to seeing what you have planned
mines a s1 with 330+bhp
i do have the full mef treatment thou, what else is there to do
What did you make of the MEF stuff when you fitted it Gus?
dont know as of yet the car was only on the road for 2 days before i started messing around again,
never gota pounding but did handle nicely, felt stable at speed too which is nice
