can i replace a rear bearing with only spanners?
can i replace a rear bearing on a s2 with only spanners, + no socket set?
my dads fooked off with it + i dont wanna take wheel off etc if i cant, tho i reckon i can...
I assume you have hammers and punches to knock the inner race out with and a pair of snips for the split pin? Screw driver for the drum? Or are you on discs?
Can you get the wheel off?
Football Cwazy
Re: can i replace a rear bearing with only spanners?
with ONLY spanners you would not be able to replace the bearing. now if you had said you had drifts,hammer etc etc then my reply would have been different
