Running cars in advice
Mitsu
500 miles @ no more then 3000rpm
250 miles @ no more then 3500rpm
250 miles @ no more then 4000rpm
Then flat rack but would you still be careful for a while ?
As for the brakes what should i be looking out for be aware of with new brakes
cheers for any advice
Mike
Mike
I personnally would never put shit oil in one of my engines, i would use only fully synthetic if i was you, never labour the engine and drive it like your mum for a couple of hundred miles and then slowly build the revs up, 500 niles change the oil and carry on increasing the revs over a short period then hurt it
you are only bedding the rings in that is all and to be fair if the honeing is real good, that should happen in the first 100 miles any way
Pugo
Pugo
Super Moderator
Pugo
Pugo
The best way to run a new engine in is:
1) Make sure up to running temp. Check oil temp not just water.
2) One run at 1/4 throttle.
3) One run at half throttle
4) One run at 3/4 throttle
5) Full throttle, now run in.
I know people won't belive me but i have seen the results of run in procedure tests.
If you do not have enough cylinder pressure to push the rings out right at the beginning your rings/bores will never bed.
The worst thing you can do for a new engine is to putle around at 1500rpm for 1000 miles!
If you run in 1000 miles and take apart you will get brown sludge below piston rings caused by blow by and un bedded rings. Run in the fast way and you will have clean piston skirts and a more powerful engine.
any other opinions guys,
The above posted was what Mitsu have told me to do but the sales man did say it is excessive but there is also a warranty involved and a very nervous misses if it does go wrong
Mike
Mike
Originally Posted by Pete,RS Specialists
a little knowalge is a bad thing thing mate I suggest you do your homework first on oils and engine building before posting such rubbish which could cause damage to someones engine
i am an engineer working for bp oil....i have worked in the development of many oils , mobil one being one of them and you are a car breaker
and your telling people that they have to bed shell bearings in
yes your spot on a little knowledge is a dangerous thing
For the guy that is running his engine in, let me give you some advice , Cosworth the highly reputable engine designers, builders and manufacturers who are responsible for many F1 and other wins in motorsport recommend that you use fully synthetic oil in your YB engine at all times(including running in), i am in no doubt mitsi do exactly the same, however if you wish to take the advice of an unqualified person(in engineering or chemistry) then knock yourself out
Pugo
Jock stick with what mistubishi say, at the end of the day the provide your warranty. I would just use the oil your car came with.
For others reading this guy bought a new evo 8 320, its not a rebuilt rst engine like his sig may make you believe.
Get on That!
run it in on cheap oil
start it up run it upto temp and leave to idle for 5-10mins drain oil change filter
fill with crap oil and drive the car don't let it labour, make the engine work but don't flog fuk outta it.
engine must be allowed to use a varied rev range and engine loads find a nice country side route and go driving for a couple of hours
change oil and filter again (did mine at 500 miles)
used semi-syn oil 15-40 and did another 500 miles using more rev between gear change
once i reach 1000 miles drain and flushed oil & fitted new filter and used a good quality semi-syn oil and just need to get it setup again now
i change my oil and filter every 2000miles and always let me car warm up and cool correctly
just read post above mine if its a new car use there recommended oil thought it was a newly rebuilt motor
Super Moderator
Pugo
ask any cossy engine builder
yea right I knoe nothing youtr probaly some
as there ready to go from the factory
,I know nothing of oil,emm let me see I only just used to have all my oil tested my the supplier in my race cars
now off you go and bed your bearings in.....
Super Moderator
For the record new cars are run on low grade oil untill the first service
if spelling is all you can moan about mate I will take my time on the key board,as I aint got time to keep picking you up on your little knowlage of engine rebuilding
i rest my case
do you know what happens to mineral oil when you run it through a turbocharger seeing the colossal temps that are achieved.....and then you want to run it through the rest of your expensivly rebuilt engine
oh and don't think because you are taking it easy you won't see the temps
Super Moderator
i rest my case
have you ever seen an engine run in on synthetic oil.
Iam sure your not stupid to think you run a cossie engine in with any sort of boost do you,so no the turbo wont even get hot
and surely your not stupid enough to think a turbo in normal running will not get very very hot ?????
Ex Full Price gold member
When i had my engine rebuilt i also bought a new turbo from turbo technics and i was told if i ran non synthetic oil through it the warrenty was invalid.
When i told my engine builder about it he said that after all the money i spent on my engine i should run it from day one with the best possible oil anyway.
So thats what i did and it has been flawless since
Martin
Martin
[quote="Garage19"]The best way to run a new engine in is:
hey when you say one run what do you mean? a couple of miles, 50 miles, 100 miles? im about to run my engine in tomorow so id really like some advice! anybody ta?
Super Moderator
case you hadnt noticed guys you aint helping anyone
Sorry i thought the Mitsu bit at the top was enough to say it was not my rst.......
I have learnt though that there clearly is a difference of opinion here,
cheers mike
cheers mike
big_Rad
15-09-2017 09:36 AM
