Braking G- Force one for Porkie etc
...what G could my Escort with 6pot/356 discs pull?..Say stopping full on from 150mph....and what effect would this have on ones body who never done this before?
Just trying to work out how powerful these brakes actually are!
Originally Posted by Freddy_mercury_magic
Pulling G is awesome, i've had a dabble at aerobatics
Love it!
As for pulling G in a car, Never really done it tbh
Love it!
Pee Vee...i think F1 cars can pull G's braking!
...just wondered as i feel these brakes are immensley powerful!...didnt want to go too fast and slam on the brakes and pass out..ROFL
CUNT!
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
i dont think you will ever do more than 1 G under braking,
i dont think even F1 cars do, do they?
....so does anyone know what G these brakes can pull?
All i getting is retarded answers
...or dare i say it...its one topic NOONE can give the answer ..dissapointed as normally a question has 50 different answers ROFL
1st to 200 without NOS
PMSL @ the thought of passing out in a car that heavy on only road tyres just from the brakes
I wouldnt worry phil, you might go over a G but you wont get anywhere near enough to black out mate!
Martin i have been driving about lightly using them for a good few miles...done the odd heavy stop from 30mph now though
So over 1 G I know nothing about this...obviously the passing out bit was a joke hence the ...i just thought full on braking from say 150mph may cause you to go a little lightheaded with these brakes...yes or no to that possibility..thats all i asking
If you stand on them at 150 they will probably underwhelm you.
Those sort of speeds have a habbit of making ANY brakes feel like they arent working well enough!
Especialy if there is a corner approaching!
ur car will prob pull over accelrating! A good sprts car will pull 1.5g in the corners.
Phil - why not get a G meter - they arent that expensive, and good for setting up
Originally Posted by MattRS1600i
Originally Posted by NUTS RuS
Depends on the suspension - what have you got ?
Martin
The brakes are very good indeed, 362's on DS3000 pads. The rear end looks high because on the short sprint circuits I run the car high at the back to make it oversteer a bit. And then run softer settings on the front to help this.
Faster real circuits the set up is very different, for instance I ran a completely opposite set up for Rockingham than that of the Top Gear sprint day.
Kev
Kev
PassionBMW.com Member
Get an accelerometer and measure it!
Aircraft/Rollercoaster G's are pulled through the vertical axis though, totally different to the braking G's, which are along the longditudinal axis....so no danger of "passing out" etc!
Originally Posted by Kevin Atkins
Martin
Kev
Kev
Caraholic
Neil,
If his car could even do 150mph, that would be a start .
Phil,
You want some proper brakes, none of this girlie 356mm stuff . Seriously, you should find that at any speed with these brakes, it will be like throwing an anchor out of the boot . You will certainly need to be bracing yourself against the steering wheel . To gauge the effectiveness of them, measure the bruising on Jen's breasts .
Phil,
