TRACK GURUS AND MIKE R-----ABS brakes and Track Driving.
#43
0-60 in 17 seconds (eek)
Originally Posted by Stu @ M Developments
When braking hard into a corner you tend to be starting the steering phase and thus sending the weight to the outside wheels of the car. When you do this, the inside wheels go light and have a tendancy to lock up briefly whilst the outside wheels are still braking effectively. When this happens with a YB ABS system, the ABS will activate and will stay activated the whole time the pedal is pressed.. NOT Ideal at all.
#45
Chasing Radders
Guess what.
Im all my new found excitment i forgot all about it
But it only cut in a few times so not to worry, I will unplug it next time once i am a Track Regular
#46
I find that with the RST the ABS starts to cut in under heavy braking even with grip to the tyres, then the RST ABS system removes around half the braking i had and pulses the brakes diagonally front and rear causing only 2 wheels to be doing the braking at a time thu = half the braking i had
Where as with the whole ABS removed and in the bin somewhere i have a better feel of the brakes and im in total control on how much braking to the point of locking the wheels without losing half my braking power because the system decided it was locking wheels.
I works sooooo much better without my ABS and i can hit the brakes knowing that i can get to the point where they are just starting to lock and hold it there and not worry that im suddenly going to lose some of this braking force. Its also nice to know they gonna work the same ammount every time i brake
Tank Mike
Ford Focus ST Parts for Sale
18-05-2016 09:38 PM
