thermostat housing gasket for a 2wd saf
just finding my feet
halfords do sell em,,,,,,,,,,,, but there the wrong one, you have to make holes for em
basically its a multifit gasket with all the drillings but one of em line up properly
not too desperate as they car is cool. just took it off to fit the new thermo today and didnt realise that there was a gasket. can get one from ford and do it monday...
Originally Posted by Eagle
get a ball bearing bigger than the hole, and gently tap it with a hammer over the gasket when its lined up over the hole
then you can use a ball bearing then, a hole punch is still easier
how many people have ball bearings lying about
even when you have a hole punch, sods law says it won't be the right size
just swapped the thermostat for an 88 degree one. managed to use the old gasket again.
temp sits about half way.
fans still run alot more than they used to tho but think thats to do with the cams and not being mapped yet i.e running abit hotter
cos it has not been mapped for the new cams yet...(wilder than BD10's)
spoken to a couple of experts on this subject and both confirmed the same... something t do with the vaccum in the inlet manifold now being different.
my understanding is...
longer duration and higher lift = more air but without the fuel to match it will be running leaner=hotter
wil be sorted when the management is fitted and mapped
Russ Payne
25-09-2015 08:29 PM
