Coil Over help
Old Sep 3, 2005 | 10:19 AM
daviddunlop83's Avatar
daviddunlop83
Default Coil Over help
Im fitting GAZ coil overs to escort cosworth and they fitted fine but the threads at the top is too high and the bonnet wont close
Here is a picture of what way i have assembled them, can anyone see whats missing or wrong?
Here is a photo of the parts left from standard shock
Old Sep 3, 2005 | 10:21 AM
Graceland's Avatar
Graceland
Team HOTHOT!
that looks right - ypu may have to remove some of the sound deadening, but i can't see why they are giving you a problem as they are
Old Sep 3, 2005 | 10:22 AM
daviddunlop83
I thought it was right too but when u close the bonnet it is holding it up
Old Sep 3, 2005 | 10:25 AM
dave cos4x4's Avatar
dave cos4x4
Stupid q but Have you put the rubber type bush in there.
Dave.
daviddunlop83
Yeah i didnt remove it
Old Sep 3, 2005 | 10:26 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
I'm sure you have worked out whats wrong you have one to many pieces there
Old Sep 3, 2005 | 10:27 AM
daviddunlop83
Lol what piece is that?
Old Sep 3, 2005 | 10:29 AM
dave cos4x4
could you not slaken the bolt at the top to lower the threaded bit and then tighten the coil spring up from the bottom platform.
or just loosen the nut off so it does not compress the spring that much.
Dave.
Old Sep 3, 2005 | 10:30 AM
daviddunlop83
Is the bottom nut not meant to be tight on the stop? cause its not even compressing the spring cause the coil over is screwed down
Turbosystems
Super Moderator
the shocker mounting plate was a one piece item when it left the factory unfortunately due to the hard top mount bush on the esc cossie it soon becomes a two piece item.
they need replacing on every service lol
Old Sep 3, 2005 | 10:32 AM
daviddunlop83
Oh dear well its ryans car anyway lol so he may get it ordered. i take if u mean the gold part and the like bearing part is meant to be one?
Old Sep 3, 2005 | 10:35 AM
Turbosystems
Super Moderator
no the bearing is seperate the gold part is supposed to have a 12 mm hole in it not the centre ripped out ,the gold part should be under your nut.
DIY rules
Old Sep 3, 2005 | 10:36 AM
daviddunlop83
If that part was one piece it still wouldnt make the treads any lower would it?
Old Sep 3, 2005 | 10:41 AM
Turbosystems
Super Moderator
the spring top is supposed to slide over the shocker shaft the bearing is supposed to mahe contact with this just like the standard spring top plate then comes the (gold plate one piece item)not the special diy gold plate you have then comes the the long nut then the top mount bush the car the top plate and then the top nut.If the threads are still to long you need a spacer on the schocker shaft below the bearing.
Old Sep 3, 2005 | 10:43 AM
Turbosystems
Super Moderator
the shokers are probably made to fit roller top mounts not road top mounts
Old Sep 3, 2005 | 10:53 AM
daviddunlop83
Where would u get spacers?
Old Sep 3, 2005 | 10:54 AM
Turbosystems
Super Moderator
personaly i would get them off my lathe
Old Sep 3, 2005 | 12:11 PM
SteveB's Avatar
SteveB
Finis code for the broken bit..... 6150341
Old Sep 3, 2005 | 12:25 PM
markk's Avatar
markk
Turbosystems,
lol
Old Sep 3, 2005 | 03:12 PM
Karl's Avatar
Karl
Norris Motorsport
Only issue I can see is exactly as Tony said, the gold top suspension mount has it's centre cracked out.
Replace these with new items and reassemble with the gold nut above this mount and you will find everything is spot on!
Old Sep 3, 2005 | 03:40 PM
Turbosystems
Super Moderator
THE REAL ISSUE that I can see karl is that he hasn't a clue what he is doing
would you like to volunteer as the test driver karl I'd sooner be test pilot for the shuttle roflol
Old Sep 3, 2005 | 03:43 PM
Karl's Avatar
Karl
Norris Motorsport
LOL, Tony with the variable caster and camber his car must have I'd rather pilot a one wheeled tri-cycle!!
Old Sep 3, 2005 | 03:49 PM
Turbosystems
Super Moderator
it'll probably handle better
what else can you do for a party trick karl I used to be able to spin on my dick till I got scared of hights roflol.
Old Sep 3, 2005 | 03:51 PM
Karl's Avatar
Karl
Norris Motorsport
ROFLOL
Old Sep 3, 2005 | 04:29 PM
ryan_belfast's Avatar
ryan_belfast
It seems mr dunlop is getting a bit of a lacing hahaha....
Old Sep 3, 2005 | 05:43 PM
daviddunlop83
I dunno what you are laughing about ryan it is your car
Old Sep 3, 2005 | 05:48 PM
Paul_RS's Avatar
Paul_RS
He does in fact know what he's doing
He has fiited suspension to quite a few of our cars with no problems. I'd say the suspension is not right.
Old Sep 3, 2005 | 05:50 PM
daviddunlop83
[quote="daviddunlop83"]
I do know what im doing, i have fitted loads of suspension. Never an escort cosworth before tho.
I came on here asking for advice not get abuse from you.
As u said the shock was assembled correctly and we got the new part. The threads still hit the bonnet
Old Sep 3, 2005 | 05:52 PM
daviddunlop83
Shut yr mouth ryan
Old Sep 3, 2005 | 06:47 PM
Turbosystems
Super Moderator
spacer time then if u send us up a shocker wheel make you a pair to suit
Old Sep 3, 2005 | 07:44 PM
NUTS RuS's Avatar
NUTS RuS
Send them back to GAZ
Old Sep 3, 2005 | 08:10 PM
ryan_belfast
I think thats what im going to do. And ask for a full refund at the same time, its been nothing but hassle from them....Dan @ Rapid ford has been on the phone constantly for me to them, which is appreciated dan so thanks, they just seem to be taking the piss.
Old Sep 4, 2005 | 07:00 PM
ryan_belfast
Will GAZ take the coilovers back and offer a full refund do you think?
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
beller
Sep 21, 2015 04:13 AM
