zetec 16v wont go in mk4 bay help plz urgent
Old 28-08-2005, 07:54 PM
xr4x4rs
xr4x4rs's Avatar
Default zetec 16v wont go in mk4 bay help plz urgent
as title
i have been trying since 11am to now to try and get this engine in
the problem im having is i can get it to line up to the box but the bolts go tight and wont do up anymore and theres still a gap
now im using zetec clutch and my original release bearing as the zetec one is bigger than the input shaft
also the water pump pulley rests against the inner wing
i want to know is
what clutch and bearing do i use
and do i modify the chassis leg for the water pully
any help please as car is stranded round my mates with engine half in still on hoist
and ned the car by tuesday
thanks rich
Old 28-08-2005, 08:15 PM
studabear
studabear's Avatar
have u checked the clutch on the gearbox splines
Old 28-08-2005, 08:22 PM
xr4x4rs
xr4x4rs's Avatar
clutch lines up ok
but engine wont pull up to gearbox by about 1cm
im thinking its something to do with release bearing
but need someone who has done this conversion so i know what to use
also if anyone has a pic of drivers side inner wing showing engine fitted with water pump pulley on
can you please post it up
thanks
Old 28-08-2005, 08:27 PM
studabear
studabear's Avatar
whip the bearin out an see if it goes rite in pain i the backside but atleast u will know
Old 28-08-2005, 08:55 PM
Sketch
Sketch's Avatar
What flywheel are you using?
I use a complete RS Turbo clutch in mine.....
Old 28-08-2005, 09:00 PM
tonyturbo
tonyturbo's Avatar
me to
Old 28-08-2005, 09:11 PM
Matt Lewis
RS & ST Parts Specialists
Matt Lewis's Avatar
Have you damaged the splines on the clutch plate
Matt
Old 28-08-2005, 09:18 PM
xr4x4rs
xr4x4rs's Avatar
im using zetec flywheel
is this wrong then
please help
what exactly do i need to use off a mk4 onto this engine
thanks
Old 28-08-2005, 09:20 PM
Sketch
Sketch's Avatar
Isnt the right flywheel the FRST one with the bolt holes enlarged slightly?
Then the RS Turbo clutch bolts straight on.....
Old 28-08-2005, 09:22 PM
xr4x4rs
xr4x4rs's Avatar
thankyou mate
just had a pm off tonyturbo and explained about the clutch senario
ive always been led to believe everything would go in smoothly well today didnt but tomorrow its going in no matter what
thanks again guys
Old 28-08-2005, 09:39 PM
DOO
DOO's Avatar
I used a RST flywheel when i done mine
Old 28-08-2005, 11:48 PM
richm
richm's Avatar
we used a 1.8L Zetec flywheel and clutch and original Escort g/box, release arm and bearing. This was on a Mk3 S1, but can't see there would be much difference?
here's a view of the fitted clearance in the MK3 :
Old 29-08-2005, 12:54 AM
xr4x4rs
xr4x4rs's Avatar
yes thats a bit of clearence there
i havnt even got quarter that i dont think
i will c tomorrow
ive tried using all zetec stuff bar release bearing but it wont have any of it
so gona put mk4 stuff on and try that
Old 29-08-2005, 07:50 AM
richm
richm's Avatar
there are a variety of photos here - www.zetec-turbo.co.uk - in the gallery if it's any help?
Old 29-08-2005, 10:21 AM
James
James's Avatar
That'll be because you have a 1cm gap between the box & engine.
When you sort out the clutch/flywheel issues and the engine will move more to the left leaving more room for the waterpump on the right.
Old 29-08-2005, 01:05 PM
xr4x4rs
xr4x4rs's Avatar
ok engine is in
what do i do with the alternator
which one do i use
as im stuck on this now
the pully off the zetec doesnt fit the cvh alternator and the zetec wont fit on the cvh bracket
so do i need to use the ztec alternator and bracket?
Old 29-08-2005, 03:00 PM
richm
richm's Avatar
use the zetec alternator and (Escort) Zetec bracket -
Old 29-08-2005, 07:56 PM
xr4x4rs
xr4x4rs's Avatar
right engine is in and fires up
had to use my mk4 engine loom and lenghten a few wires
then it would fire but wouldnt tick over so put zetec ecu and iy purs
question is now
ive fitted all the brackets and alternator but what fan belt do i use?
and what water pipes as the zetec has a very large outlet from the pump
ive had to cut and shut a lot of pipes and move my rad right over so the bottom hose isnt kinked
looks a rite mess in there but its the best i can do with what ive got
any suggestions
Old 29-08-2005, 08:16 PM
richm
richm's Avatar
is your pulley arrangement the same as my pic above?
That belt is a Gates- 68401
Old 29-08-2005, 08:29 PM
xr4x4rs
xr4x4rs's Avatar
yes it is mate
what sort of belt is that
any name off a car or the length of it
Old 29-08-2005, 09:43 PM
richm
richm's Avatar
yes it is mate
The Gates "68401" reference number is definitive, if you go to a motor factor who stocks Gates belts and ask for that number you get the right one. We just had a few away and tried them to find the right length
In principle it should be for a Escort Zetec WITHOUT power assisted steering. We didn't bother back-referencing the number to an application...
Old 29-08-2005, 11:37 PM
xr4x4rs
xr4x4rs's Avatar
ok mate ill sort that out tomorrow
also who put the bolt in on the alternator of that pic
as its the wrong way round lol
Old 29-08-2005, 11:42 PM
richm
richm's Avatar
?? bolt? which one? wrong way?
Old 29-08-2005, 11:56 PM
xr4x4rs
xr4x4rs's Avatar
first pic
its the big long bolt that holds the altenator on, top one
if th ealternator goes the how will you get that bolt out due to chassis leg in the way?
also what water pipes are used fro the water pump
thanks
Old 30-08-2005, 12:10 AM
richm
richm's Avatar
ah.. LOL sorry, see what you mean.. getting that bolt out was the least of the problems if stuff needed getting out of there
we used a Zetec water pump hose - was a tight squeeze to get it to go from the pump to the rad, and needed to be trimmed a little short on the pump end to get it to fit half handy. This hose also has a T-stub moulded in that goes into the cross-tube that runs along the slam panel. (goes to the thermostat housing from memory)
Old 30-08-2005, 12:24 AM
xr4x4rs
xr4x4rs's Avatar
what ive done is
used the zetec water pipe and moved my rad right over so theres no kinks in the pipe
now the original cvh had a pipe that went upo drivers side inner wing which im not using now ive turned the matrix pipe round and the two matrix pipes go to the stat housing now
and that pipe that runs a long th eslam panel is the same except goes to my header tank and the one that goes to the heater pipe is blocked off
does that make sense
Old 30-08-2005, 12:49 AM
xr4x4rs
xr4x4rs's Avatar
also where does your header tank feed go as im using the efi mk4 which is on passenger inner wing and goes to that metal pipe then goes to water pump
will c if it works tomorrow
Old 30-08-2005, 06:26 PM
xr4x4rs
xr4x4rs's Avatar
im still struggling on a fan belt
ive tried 10 on today and there all to small or to big
the problem im having is no one stocks gates belts so im using qh
does anyone have a part number for qh of the belt i need
its the lawst bit thats need to finish the transplant
thanks
Old 30-08-2005, 06:59 PM
digita1dragon
digita1dragon's Avatar
get a piece of string round the pulleys, mark it where its as tight as it gets, then mark it again when its right open, then get the smallest belt possible in that range as they stratch after a few hundred miles
Old 30-08-2005, 08:00 PM
xr4x4rs
xr4x4rs's Avatar
tried that but failed mate
will try tomorrow now as im shattered and its my birthday lol
Old 30-08-2005, 10:16 PM
digita1dragon
well happy birthday
Old 31-08-2005, 07:00 PM
Moondust_crust
Moondust_crust's Avatar
have you got any pics of your engine install mate so i can have a look for when i do mine, many thanx.
Old 31-08-2005, 07:41 PM
xr4x4rs
xr4x4rs's Avatar
not yet mate but will do soon
it looks a bit bodge in there at the minute as im mixing and matching things on the water sides so doesnt look pretty
just finished it all in the thunderstorms just now went to turn the key and it went pop and the cambelt snapped
so hopefully havnt done any damage will see tomorrow when i fit a cambelt
Old 31-08-2005, 07:57 PM
scort
scort's Avatar
I used a CVH fiesta alternator bracket,
Steve
Old 31-08-2005, 08:20 PM
xr4x4rs
xr4x4rs's Avatar
ive used the zetec one as it was there and finding a mk3 fiesta in a scrppy with that on is gona be a nitemare round here
the only problem im really confused on is the water system
i mean what do i use in rad terms and where do he pipes go and where they join to
like i say ive bodges it at the minute and have somehow managed to bodge a zetec rad in there but looks a mess and want it proper
any one shed some lite on the water side ofr me thanks explain what goes where
Old 31-08-2005, 09:35 PM
andre_k
andre_k's Avatar
cam belt snapped??? unlucky m8! hope its ok...
was the zetec conv easy?
dre
Old 31-08-2005, 10:46 PM
xr4x4rs
xr4x4rs's Avatar
its fairly straight forward as long as your car is efi already
as mine is the efi mk4 there wasnt much of a problem
and the people so far who have helped carnt fault as its correct
Old 02-09-2005, 07:17 PM
Moondust_crust
hi mate tonyturbo reccomends using a mk4 rad as it will fit better in the slot provided, im not sure about the coolant pipe side of things though, just use whateva fits, trial and error, good luck with it all dude
Old 02-09-2005, 09:45 PM
xr4x4rs
xr4x4rs's Avatar
right having sum unlucky probs at the minute
done the cambelt and i was lucky nothing bent
just had all the exhaust done so i could fire it up and the alternators gon now
now when it was running i used the zetec ecu now it would missfire and overfuel
put the cvh ecu and it wouldnt tickover, but disconnected map sensor and ticksover
now the rev counter sticks at 2k and hardly moves?
and theres just pure fuel coming out of the exhaust
i swapped the two outer wires on the tps and that stopped the fuelling issue but then came a flat spot and 2k issue with the counter
do i need to use cvh coilpack instead of zetec to solve this
water issues im going to sort as i need to modify a rad to allow the header tank pipe in
any move advice from the gds who do zetec cus im buggered if i know
thanks
Old 27-12-2017, 10:08 PM
Kris Mainwaring
Kris Mainwaring's Avatar
is this wrong then
please help
thanks
have to use efi cvh flywheel and rs turbo clutch in a mk4 zetec conversion....
Quick Reply: zetec 16v wont go in mk4 bay help plz urgent
