big wing sumps / baffles / gates / blah
people talk of these with having gates baffles etc, but the one i saw had holes drilled in the sides of the sump to allow oil into the wings... i guess that there isnt anything in the wings for the oil, but the holes act as the baffle??
CUNT!
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Re: big wing sumps / baffles / gates / blah
CUNT!
Gates have fook all to do with holes... until you close the hole with a gate...
basically had a big winged sump, it had holes in either side of it that had been drilled. then it had tanks welded on so that the oil can go into these tanks.
all i was asking is this:-
do the holes act as a baffle and no gates in the tanks themselves, or is there gates in the tanks? just want a better understanding to improve my limited knowledge!
Originally Posted by Mr C
Originally Posted by marco polo
Mike
this is the daddy sump for a 2wd cossy
Marco
Marco
OOooh where can I get one, need one of those
Hi Mate
i can get them made to order but i will need a normal 2wd sump in part ex your oil pick up pipe will need to be modded (moved further back)
it does matter which oil pump your useing or pick up pipe (2wd/4wd/eecv)
proper pice of kit and they work very well
