Sierras on 18's
Sierras on 18's
Any of you guys running 18's and if so does the black rubber band allegedly called a tyre work ok or is it just too low profile to give decent handling
Need to no asap as have been offered a set of new oz 7.5x18's with 4x toyo 215/35 for much less than the wheels alone are worth
be rude not to if they work
cheers matt
edit to say i'm running fully adj everything if that helps
cheers matt
cheers m8
Yep I know they will fit as rolling radius is not much different to 205/40 17
offset is good
just worried if profile is too low for decent handling
offset is good
Chasing Radders
Not sure on the off-set as i got them off Spadge and it isnt printed on the rims
I had to trim the front arches a little as it would catch on full lock when braking. But i run old Koni's so they will be a little saggy.
ive got 18's on mine and tiffs tramlines coz its unevenly weighted on one side mines ok offset35with 225/35/18 on the back and 215/35/18 on the front, no probs at all
looked at ur car but didnt get a chance to speak to you about it. given me the inspiration to go with 18's on my own. it seemed to go well on the track too. looks the part. what offset are your rims?
not a clue on ofset mate thay where on it when i got it but the front arches have been cut and the f bumper moved forward a bit . the motor wasnt right when it was it nokhill the exhaust cam was wreked and the timing was 2 teeth out but its away geting done low comp pistons with valve cutouts cometick gaskets and bd14,s its got grays , level six brain stage 4 bbr chip 500 cooler and a stage 3t34 so it should be better when she is home . its my first cos so im just learning
chowfornow
14
05-01-2019 09:01 PM
SMILER258
28-09-2015 09:04 AM
