Is this standard RST compression?
Just done a compression test on a second hand RST engine I just purchased.. The results were:
1 = 145
2 = 150
3 = 145
4 = 155
Some variation between cylinders there, but I`m more interested to know if this sounds nearer to being standard RST compression, or low compression?
Any info, is much appreciated..
Thanks
1 = 145
2 = 150
3 = 145
4 = 155
Thanks
Putting it simply, you have to calculate the swept volume of the cylinder and then divide in to the chamber volume and that will give the comp ratio.
Steve
Steve
TPM961
15-01-2018 10:50 AM
