zetec tick over(the plot thickens)
my car point blank refuses to.
itl start up tick over for 5 - 10 secs. cough splutter and die. fookin typical. 2 days before knockhill.
the idle air control valve is disconnected and the idle screw is nearly right in. worked fine like this for months.
any ideas folks???????????
i know. its the idle air control valve that was sticking but uv got to take inlet etc of to get it off. bit of a mare to say the least. doubt i'l be at knockhill now.
believe me the revs would have been up anyway. regardless. bought a new act sensor from ford. wrong 1. its what ford list as a act sensor for a frst. deffo not right.
ticks over perfectly when cold. just took it out and ragged fook out of it just to see if it wanted to cure itself. goes like fook. leaves black marks all over the place. the odd brown one to i must add.
this car is really bursting my happiness. had to come into house or i was gonna cause some serious damage to the fuckin thing
(real tears nearly)
any ideas folks. it starts up no problem at all. runs for 5 secs then cuts out. every single fuckin time. has been fine up until yesterday when it decided to fuck up. piece of shit. FOR SALE
(real tears nearly)
put my original xr3i ofac ecu back in and hey presto. ticks over like a dream. is it ok to run it like this??????
idle air control valve removed completely as well now.
just finding my feet
erm, did you swop the pins when ya changed the ecu
and where did ya get a ofac xr3i evu from
also what mapsensor ya using
infact run through exactly what ya have done to the car to run it on efi !!!!!
whats been fitted ect
this is fook all to do with it tho. its ran fine for long enough.
When you start a car the first few seconds is very rich due to the after start fuel enrichment.
If your ecu does not fuel correctly (faulty sensor etc) the afterstart enrichment might be allowing it to run.
Darren
Darren
the car was put on the rollers at AVA when it was first running (mar 04) just to check fueling etc. obviously couldnt run it up much as it had basically no miles on it. they said then that it was safe to use after they checked it. so it has been set up to a certain degree. in approx 10-12 weeks i hope to have it mapped and complete at msd. cheers for the concern. i think i have done well considering i'm a formwork joiner to trade.
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
