New stainless is leaking!
Just fiited a new stainless exhaust to my car (mongoose) and the joint from the first section (downpipe) to the middle section has a very small leak, i have tightened the clamp as much as possible, will it sort itself out after a bit of use or will i have to gum it up? Its only a very small one
if i put a bit of paste on it can i just do it round the joint or will i have to remove it, separate the joint and get the paste inside and refit?
Originally Posted by COSSIENUTS
iot will NOT fix itself mate use some paste as above
