Snap off boss help....
I'm just trying to fit my snap off boss on my MOMO wheel and I've got a feeling I'm missing a part
Has anyone got a pic of the back part of the steering wheel when diconnected? (needs to be horn push in the centre please...)
If the holes on the wheel don't line-up with the snap off thing then you will need to get an adaptor that goes in between the two to allow you to fit the Momo wheel!
Its not that mate I've taken care of that already, its the horn push, there doesn't seem to be anything on the back of the wheel to line up with the 2 brass insert bits, so I'd have to pull the connections off every time I pull the wheel off!
Ok i think i know what you mean?
This is a pic of one i have the part on the left is attached to your wheel and the part on the right is attached to your boss. The 2 brass bits line up with the two silver bits to complete the circuit for the horn.
Originally Posted by Wes RS
Cheers for that mate, looks like I'm gonna have to sell it then as my horn push is totally different to that
Get your head round that lot lol
I'll go get a pic of mine lol
thats the bit thats missing by the sound of it....
then on the reverse of the snap off part on the left are 2 further spade connectors which attach to your horn push!
here you go mate, my batteries died so I didn't get a pic of my steering column but it looks the same as the right hand side of your pic you put up
the reverse of my wheel....
Does it look like someone has cut the centre out?
I've just found out you can un bolt the snap off wheel part into 2 bits again and there looks like a ridge where an extra piece fits (which must be the optional horn push bit...)
If you look on the reverse of the part in the left of your pic there should be 6 allen key heads, if you undo them I'm betting the horn push bit will come out seperate
Will have a look and see if you can get this part on its own
Cheers for your help Spadge
I think thats the bit I'm missing as Radman says, its sandwiched btween those 2 parts...
If its old style I guess I won't be able to get hold of it now...
S1 Database Editor
If you sell it Wes, might be interested at te right price..S1's don't have centre horn: it's on the end of the stick thing.
Hope you sort it either way. Can you not take it back & tell them there's a bit missing ??
rsguy
44
29-09-2015 03:29 PM
