Saph front bumper fix?
Just got round to fixing my loose front bumper
It's the triangular holes in the wings that are fooked, so I'll be making up some plates and getting them welded in, but I cant get the bolts out of the bumper mountings
I reckon I'm gonna need new bumper mount brackets, but how do you get the bumper trim out of the bumper to get onto the heads of the rivets?
Are the brackets still available?
Neil.
Neil.
Yeah just replaced mine pal, 65 quid for a braket set which includes both sides, they do have a captive nut within the plastic braket so its more than likly doing what you sed.
When the bumper is off you just drill out the rivets and re rivet the new brakets on,my bumper sits much better now its be sorted
Hop this helps
Hop this helps
When i did mine, i just prised the end of the strip out from the bumper, then peelled it back just enough to get to the rivets... Prob best to mask around the strip to avoid scretching the bumper...
0-60 in 17 seconds (eek)
Ran,
watch out, cable ties are only good for a while, the sharp edge on the metal triangle cuts them off. I should know, my bumper fell off when I was parking the car, luckily didn't happen on the motorway at speed only a few minutes before
There is a post in restoration/rebuild/projects that I made a while ago re bumper refit, including making plates for the little triangular holes if they are rusted.
Shames searches don't work
Hat's off!
I've ordered the bits from Ford yesterday, so I can crack on with it if I get off my fat arse and get over there to pick em up!
I've left a reply for you over there to keep it all on the same thread
Thanks again!!
Neil.
Thanks again!!
Neil.
jessie_rs
11
03-06-2019 04:57 PM
adam151082
30-08-2015 08:34 AM
