Cheapest place for AP Discs & DS2000 pads???????
Need a pair of GENUINE AP Racing 330mm T2 (two triangles) discs for Es Cos + Ferodo DS2000 pads (fast road use only).........
Who can supply the above at the best price????????
As I suspected - forget about putting DS2000s on it . Put DS2500s, as they are a better compromise for fast road use .
I would also forget about putting traingular discs on, as they will cause the front end to wobble like a bastard. Stick with the normal round ones.... .
I have DS2500's on my Es Cos now but the problem is I miss the initial "bite" of the DS2000's that I had fitted on my Bailey Saph.....Also, the DS2500's are also VERY hard on discs Wont be doing many track days anyway.
The reason that I need new AP discs now is because the DS2500's are only about half worn, but the discs are VERY worn!!!
Maybe I will consider the grooved AP discs - are you sure that the T2 discs cause a wobble as I have never noticed it
WILL NOT USE DRILLED DISCS EVER AGAIN.......as all they do is crack
I thought that you were saying that the T2 discs had an inherrent problem I'm a bit slow this morning as I was up at 4.30 AM
Doug,
Wooosh, straight over your head
You must drive like an old woman then .
You're looking at around the £90 mark for DS2500s and slightly cheaper for DS2000s.
Mike, do you agree with me about the "bite" of the original DS2000's ???? I do feel that the DS2500's dont have such good initial stopping power, but get better as the discs heat up...Have you found this too??
What caliper, and I can get you a price........
Sorry I missed your post........They are the 4 pot (5200????AFAIK)......they are the as supplied in the 4 pot/330 mm disc AP kit
07-10-2015 12:56 PM
