RS500 track toy running issues.
Evening all.
Right ive finally managed to get my RS500 track car to the rollers today to be mapped but unfortunately it didn’t get that far and hoping someone might be able to help.
We we had the car running a few months ago for the first time and although a bit lumpy as some sensors needed changing and it needed mapping it was one of the quietest yb’s I’ve ever heard, the oil pressure gauge was reading right (can’t remember what it was but my mate said it was right) and all seemed fine.
Now a few months down the line we took it in today to be mapped and as soon as it fired up it started to tap almost like a stuck lifter (hydraulic lifters) but it wasn’t constant with the engine revs and seemed intermittent (top end noise) we stripped the cam cover off and everything seemed fine, now the oil pressure gauge was stuck on 8bar (max on gauge) and we decided it was a faulty sender but thinking about it the sender came with the gauge brand new.
So my question is would maybe something have happened where the oil pump isn’t working right and maybe starving top end of oil hence the noise or am I talking shite? It’s a very strange intermittent tap/knock from the top end but before I pull it apart I’m hoping there maybe an easy fix.
Any help would be appreciated.
My saph had that same intermittent tapping when cold was sticky lifter
3drRich (19-06-2019)
As we couldn’t really see anything obvious thought it may be a broken valve spring? Would that make an intermittent tapping noise?
It seems to be coming from the back of the head if that helps?
You haven’t given enough info. Type of parts used make of lifters. When oil pressure is high. What is oil pressure on tick over. Where cams dialled in. Do pistons have valve pockets. How long car was on dyno. Does it have oil cooler. What dyno what fan. Many things can go wrong.
Mark
Mark
Mark
Mark
If the gauge is reading 8 bar with the gauge powered up but engine not running, you have a gauge issue. your best bet is to use a known good mechanical gauge for diagnostics on oil pressure.
If it has 8 bar of pressure when warm I’d defo be checking the pump
3drRich (21-06-2019)
I won’t be able to make that much pressure on tickover so most likely sensor fault.
Double valve springs can tick intermittent with one broken and still run ok.
The black style lifters are total crap so you need to know more about he spec to find your fault easier.
Mark
Mark
Mark
Mark
You are right and ultimately it will be but it’s just annoying as it was fine and nothing has changed since the last time it was run and wondered if it was something simple.
3drRich (22-06-2019)
Sorry forgot to update this. Well it was the small end bearing on cylinder 1 and on closer inspection there was partial detonation to the piston on cylinder 1 so we made the decision to go a more modern spec with a full rebuild and new turbo setup.
The engine is all back in now and was due to go back to the tuners last Thursday for the new management and rolling road session but for obvious reasons that didn’t happen which is a shame as I’m desperate to get out in it now.
Mark
It looked like the oil pickup was very dirty so Not really sure to be honest as once we opened it up it was decided very quickly I wanted it rebuilt.
My own fault really as I bought I 500bhp carbon fibre puma (sure you know the car) for its running gear on the understanding that it was built by a reputable guy bla bla bla and sure enough it had the right bits but certainly wasn’t built by anyone reputable. On the plus side it has an original 200 block that’s never been bored and i broke the car so the guts of the engine which is what was basically left owed me about right so I was lucky in that respect but I did think of it that way when I bought the car.
coswurv
16
20-08-2012 07:22 PM
