Mk1 fiesta st170 conversion
Hello all
need some help on finding the right parts and info on fitting the st170 engine into my mk1 fiesta I have the engine and a ib5 gear box
what breaks can be put on this car
suspension
how much do I need to cut out the chassis to get the umps to fit
engine management system
any info would be great
thanks
My son has done this to a mk2 fiesta he used Mk1 mondeo servo and master cylinder with wilwood calipers and Sierra xr4x4 discs. His run s on bike carbs with Nodiz ecu making the spark.
Ithink you need a water pump impeller that goes the other way.
Not sure about cutting the chassis leg as the mk2 is different
See it here
https://passionford.com/forum/restor...-st-170-a.html
See it here
Thanks mate do you have any photos of this I also have a mk2 with a zvh turbo in
thanks for the info I was looking to buy the wilwood break system next week
I have a zetec turbo in mine . I used xr2 alternator mount, modified cvh engine mounting and e escort water pump . I've got a spare brake setup up if your interested mk2 hubs with low mileage bearings Mondeo v6 callipers and rs 2000 discs . I'm not to far away from you to . Drop me a pm if interested Keep the pics coming
cheers
cheers
Mk1
Yes mate I’m interested in them pal I just need patterns so I can buy some new disc really will the bolts onto the front and what did you do about the rear breaks ?
The discs have no wear just light rust , both discs and pads have only done a few hundred miles tops . I didn't do anything with the rears I'm always causious of over braking on the rear
Parts list so far
Fiesta st170 -
Engine. St170 -
Gear box ib5 -
Clutch LUK std clutch kit 220mm: Ford Escort Mk4 & Fiesta RS Turbo CVH 622131600-
Fly wheel -.efi -
Poly bush kit for rear-
Rear breaks - all new
Mondeo mk1 master cylinder and servo -
Front breaks -
Engine mount - da performance
Cradle mounts da performance
Water pump mk6 escort
Belt puille - da performance
15 inch Cosworth alloys
Custom Karl linkage -
enhine rebuild kit
Engine. St170 -
Gear box ib5 -
Fly wheel -.efi -
Front breaks -
enhine rebuild kit
I think there was something funny with clutches but it was maybe because he has a billet flywheel. I’ll ask him tonight.
I was wrong ....
You need RS Turbo friction plate and cover and ib5 release bearing.
Looks like a great project, I'm interested to see the next update
TomPengelly
24-08-2020 07:48 PM
Andypandy260
23-09-2015 10:28 PM
XRT_si
102
12-06-2012 09:48 AM
scotty86d
44
04-08-2010 11:47 AM
