why would abs light come on after changing callipers + disc's?
Upgraded the callipers + discs on my mk5 fiesta zetec-s with with fiesta ST150 items on the weekend. The parts are a straight swap, but when I went for a drive afterwards the abs + traction control lights came on for about 1/4 mile then went off again. Why would this happen? They work absolutely fine.
I didn't touch any sensors or connections, didn't have to use any force on anything, I was very careful.
Not used it since weekend, hopefully it was something like that. I don't understand how it works? I don't think there was any electrical connections on the hub like on a newer car.
Received 1,042 Likes
Strange. I had no problems when I fitted bigger brakes on my old puma. Did you have the ignition switched on and did you spin the front wheels when you had the car jacked up.
ignition was off, I jacked one side of the car at a time, but now you mention spinning the wheels, it was parked in gear but as I lifted one wheel off it did turn a bit and make a bit off a clunk noise from the gearbox. I thought nothing of it at the time, could that of caused any harm?
However, when wheels are about to lock (as a result of hard braking) there would be a discrepancy and the ABS then activates.
This rapidly apply the brakes, giving the effect of cadence braking, which allows the vehicle to steer and brake simultaneously.
As Rich says, I suspect the sensor is the issue here.
ESC (i.e. traction control) also uses them as an input.
Martin
The lights went off and stayed off when I first drove it, I just want to be certain it will be ok as I have a long drive across Europe next month it so it needs to be spot on.
Martin
Just been out, lights are back on again. I've had wheels off and had a good look, I can see sensors and there's no way I have touched them while doing the upgrade. although I admit it must be related to what I have done.
is it best to get it checked with diagnostic equipment? As there's no way of really telling what's wrong is there?
is there anything I can do to narrow it down?
I didn't even think of that, is that a possibility? I just bled it with my Mrs, so might be worth me doing it again. I just assumed that was ok as the pedal feels good.
yea it has obd2 which I'm surprised about as its a y reg.
thanks for your help
We'll, traction control and abs lights are on permanently now, I didn't even know it had reaction control, there's no on/off button for it.
I will try and borrow a decent reader this week, I've just got cheap one.
the car was perfect last august when I put it away in the garage, since i got it out last week and I've changed the brakes I've got this issue, the screen wash bottle is leaking somewhere and I've just gone to use it now and it won't fucking start 😐 brilliant isn't it.
It is most likely the sensor on the drivers side. Could be coincidence, or you may have unknowingly pulled on the cable or something. You can take the sensor out and test it but you may as well replace it as they are cheap enough, I bought a cheap Chinese special off eBay a few years ago and it worked fine. If the sensor doesn't fix it then I'd be checking for continuity through the loom back to the control module.
MT-Motorsport
09-02-2014 08:13 PM
MAD YUM
12-11-2006 11:00 PM
Lincolndanny
30-09-2005 09:07 PM
Ginge !
35
09-01-2005 01:15 PM
