Mk1 focus tdci battery problem
Old 13-12-2017, 08:06 AM
Fordmad!
Fordmad!'s Avatar
Default Mk1 focus tdci battery problem
So driving the other night me the battery light came on and off with lights dimming at low revs, also heater kept going off and a click from the passenger side of the dash.
Took it to test the voltage and battery with it being cold recently. Voltage running with everything on was over 14v. It came up with battery faulty. So replaced the battery yesterday and now this morning it's come on again!!!
Im thinking either alternater or wiring connection somewhere
Anything simple to look at before I start spending a fortune changing parts?
Old 13-12-2017, 09:30 AM
Do these have a smart charge system on them? I know the old transit connects used to and the wiring used to snap inside the sheaf.
Old 13-12-2017, 11:37 AM
martysmartie
martysmartie's Avatar
Correct and yes they do.
As said, the three pin plug on the alternator causes issues.
Verify it's wiring.
Martin
Old 13-12-2017, 06:04 PM
Fordmad!
Fordmad!'s Avatar
Right I'll check the wiring to the altanater and go from there. Thanks
Old 14-12-2017, 08:26 AM
Fordmad!
Fordmad!'s Avatar
Right had a poke around wiring this morning. All looks okay but not to say it isn't that. It's charging at 14.6 which I'm told is overcharging. Both garages I've used have said it'll be the alternator but I'm unsure. I'm a bit limited with time to get anything else done though. Just don't want to shell out £150 to sort the alternater and find out it's not that ����
Old 16-12-2017, 01:17 PM
martysmartie
Nothing wrong with that output whatsoever, perfectly normal.
In actual fact, its possible to see around 16V, which is why it's crucial the correct battery is installed.
I would ensure the fundamentals are verified before simply buying another alternator.
Martin
Old 16-12-2017, 01:58 PM
Cossy Mike
Cossy Mike's Avatar
My battery light started to come on after around 30 seconds of idle. They have a smart charge system on, if you listen you can hear the relay clicking when the light goes on and off, this will also drop the current on your reading. Mine was the plug on the loom that connects to the alternator as mentioned above.
This was after I fit a new alternator (which I was doing anyway with power steering pump, water pump, all pulleys, new belt etc.)
I simply unplugged it, cleaned the 3 pins and contacts, then put a little vaseline on, its been perfect since.
Old 17-12-2017, 11:37 AM
Fordmad!
Fordmad!'s Avatar
I made sure it's the correct battery as I was aware of that.
I've taken the car to another mechanic I use who's far better then your average garage one and he does think it's the altenator after testing everything.
Bought a new one that will go on tomorrow so hopefully this cures the problem!
Old 18-12-2017, 02:51 PM
Fordmad!
Fordmad!'s Avatar
Welll after about of head scratching it's sorted. I stripped back the wiring and couldn't see any breaks, so went ahead and changed the alternater and still it wasn't sorted.
So did all the wiring again and stripped it right back only to find a break half way along in the smart charge loom where it's clipped to the fan housing. Just shows you need to check all of it not just a bit!!
Cost me £100 for the alternater that I didn't need but oh well I cba taking it back off so it's staying on.
Thanks for the advice
Old 18-12-2017, 04:37 PM
martysmartie
What I thought then, it's very UNLIKELY to be the alternator itself.
Martin
wilcox
05-04-2019 08:22 PM
TurboBoost
25-01-2016 07:21 PM
marky3dr
Ford Focus RS
07-01-2011 05:41 PM
paceo
13-06-2010 11:47 AM
Quick Reply: Mk1 focus tdci battery problem
