Cosworth 205 cracked block
yet again iv cracked number 3 cylinder on my focus cosworth block I'm running the old 205 blocks at .50 over size bore iv now got 2 of these blocks that are cracked. I no it's £220 to get a liner put down each of them but will a new liner with stand 400bhp or will they re crack . Has any one relined a 205 .
I do have a 200 block but that's for a futcher big BHP motor I'm working on
New Owner
I have no idea why so that's why I'm asking. be interesting to understand why
Im hoping my 205 block will be alright as im hoping to get a fair bit more than 400bhp.
Is it something to do with the #3 not getting the same amount of flow as other cylinders?
Would a different inlet not fix that issue?
over 400bhp costs a lot to do if you want it to be safe and if you crack a block then you have some big costs coming your way anyway at a time when you might not want it.
cossie fan (unluckerly)
I didn’t think there was enough meat in the 205 block too fit proper liners that strengthen the block. Obviously you can sleeve them but that’s not the same
I would either get a 200 block, get your 205 linered or go all out and get the Ally Smith and Jones which seems mega bucks but the cost of a good 200 block and having that checked and worked on is not cheap either.
450bhp should be reliable enough in a 205 block if done right, although i am now also thinking of reworking the head whilst i have the opportunity
The problem is a 30yr old block that has corroded from the water jacket.
The 200 blocks crack across the stud face, the old 205s crack the bores when old.
The fix is using a spun ductile liner. If fitted correctly will resolve your problem with a known material at a known thickness.
Been there, done that. Still would not buy a 200 block.
how much does it cost mark to do it right with the spun ductile liners ?
Location: it's not where you are, it's where you've been and where you hope to be
some years ago there was a long thread on here comparing 205 v 200 blocks and one of the contributors was Karl Norris. He described in detail the weak points of each and iirc was generally in favour of 205
All depends on a persons budget. I’m going 680 on a 200 block with ductile liners lots about like that perfectly strong enough. Of course the alloy block is better but expensive plus I certainly couldn’t see the point of putting a 20 year old crank in one so would also cost me 3 grand for a crank
james kiely (30-10-2017)
If people tend to push the boundaries on 200 block cars then it is likely that more of them would have cracked. I wonder if there are more 200 blocked high power cars out there? Maybe something to do with more being 4WD????
I was always under the impression that the 200 was the better block to go for when going big power but it is only from what I have read on here.
but a 200 with a crack across the stud holes works fine when long studded so why don't you like them?
Sorry, structural integrity has been compromised as soon as they crack.
Scrap only at that point.
I think it's been well proven a longstudded 200 block can handle crazy hp.
maybe a minor impact upon structural integrity but its nonsense to say they're scrap - plenty of 200 blocks around which were long studded to circumvent a crack from the stud hole
There are way to try to rectify or to try to re-gain this but every way to exactly that, bodging up the failure.
I could wrap the whole thing in C20 concrete, that will stop the sides coming out of it, does that make it correct?
The correct way is to replace the broken part.
1st to 200 without NOS
A hairline crack from the thread to the water jacket isn't uncommon to find when the head is removed, if its a 200 block then it can be saved by long studding, I've lost count of the amount of times I've done this over the years and its completely successful with no problems even on high power engines.
The fix is to modify the original part to stop it cracking in the first place.
I have done several of these and non have then presented any cracks post mods.
A crack is a crack. The part has still failed.
