Q7 v12 swirl flap delete
#41
cossie fan (unluckerly)
#45
I think they should last as long as the car but you need to be careful that a tyre fitter doesn't sink the wheel on the disc and chip the discs.
#47
burnzy
you have them weighed, they have a weight limit to replace them.
they are supposed to last 60-100k miles iirc, but it’s all relative to the use they get, i’d like to think a v12 q7 would probably see the lower end of the scale due to it being inherently heavy on brakes.
#50
burnzy
they are suposed to be on another level though, I know someone who has Aston Martin ceramics on his b5 rs4 and he says when you feel like you’ve gone waaayy past the point of no return before a bend that’s when you can brake and even then you’ve braked too early
#51
#52
@scoooby slayer Hi again. The people I spoke to (Darkside) said the intake had to be removed for the swirl flap delete.... that's an engine out job. At that point I may as well replace the intake. Were you able to code out the swirl flap without physically removing the flaps?
