Cosworth straight cut box info.
Old 15-09-2017, 07:28 AM
  #41
cossynut2
cossynut2's Avatar
Originally Posted by stevieturbo
Small....I'd say variable, rather than small.
Just depends on driving type at the time, type of clutch etc etc
Sometimes you might be able to make it pretty smooth, others not. But a lot depends on overall drivetrain to. If everything is fairly tight, box rubber mounted etc then any clunks would be less noticeable anyway.
But you can never expect it to be as smooth as a synchro box. But then a full manual synchro box will never shift like a dog box when racing.
A few years back the Nissan Skyline GTR gearbox conversion was considered a good option for a big BHP Cosworth. Does anyone still offer it and how does it compare to these gearboxes which you are talking about?
Old 15-09-2017, 07:45 AM
  #42
Caddyshack
Caddyshack's Avatar
As far as I am aware only Reyland offered the conversion. My bellhousing when I had Skyline box was done by MK but Coley and M K with the WRC Fiesta cut and welded their own bellhousings to stitch on to the cossie end.
The reyland one was an OS Gicken kit but it was £10k drive in drive out job.
The Skyline box is a lot heavier than a standard box
Old 15-09-2017, 09:40 AM
  #43
grcossie
grcossie's Avatar
The Skyline Box is nearly 40kg heavier than a standar box, it`s alot
Old 15-09-2017, 09:43 AM
  #44
Caddyshack
Caddyshack's Avatar
I took my skyline box out of the car at least 8 times before it worked and that was flippin hard work, when I went back to the MT75 it felt like I was changing a starter motor in comparison.
Old 15-09-2017, 09:51 AM
  #45
Jay,
Sponsor
Jay,'s Avatar
And they might take the power but fail in many ways imo not a good upgrade as its not anywhere near a fit and forget option lol
Old 15-09-2017, 10:50 AM
  #46
stevieturbo
C**t
stevieturbo's Avatar
This thread is primarily about 2wd boxes....4wd obviously changes the options
Another popular box these days for those wanting a synchro is the 350z CD0009
Ratios may not always suit, but the boxes are fairly affordable, will obviously shift very good being modern Japanese and are supposed to be very strong.
There are many fitting kits for different motors ( 2JZ, LS V8, Various Nissan engines etc ), although I doubt a Cossie is one of them.
http://collinsadapters.com/index.php/swap-kits.html
Old 15-09-2017, 03:44 PM
  #47
cossynut2
cossynut2's Avatar
That is a big extra weight to carry which I was not aware of.
Old 15-09-2017, 03:47 PM
  #48
cossynut2
cossynut2's Avatar
A lot of money when you you compare it to some of the other modern gearbox options being talked about.
Old 15-09-2017, 05:35 PM
  #49
Caddyshack
Caddyshack's Avatar
Exactly, when you can pick up an rx8 gearbox to replace a type 9 for hundreds. If you can find a production car alternative it can be great.
Old 15-09-2017, 08:42 PM
  #50
grcossie
grcossie's Avatar
Alot, and the reason my mate sold his after we weight it, and bought a fixit
Old 20-09-2017, 03:05 PM
  #51
20/20 vision
20/20 vision's Avatar
Location: it's not where you are, it's where you've been and where you hope to be
I'm running a fixit semi straight cut CR 4x4 box and it is too slow to change - easy to beat the syncros.
Howevere, with drop gears & 4.4 diff it makes for nice ratios for hooligan road going kit car, prob want a different diff for a track car.
Old 21-09-2017, 05:34 AM
  #52
grcossie
grcossie's Avatar
Thats true, it`s like standar on shift. These kit have a 20degree cut
Old 21-09-2017, 06:41 PM
  #53
markk
markk's Avatar
They are not 40kg heavier at all.
I did mine over 6 years ago. I can lift the complete box. Just. I reckon maybe 10 or 15kg heavier, but they dont break on the back of a 4 cylinder unless your a knob with shifting gear.
Old 22-09-2017, 05:31 AM
  #54
grcossie
grcossie's Avatar
That was the weigt we got on my mates box, it was heavi as hell, not sure what model Skyline it comes from
Old 22-09-2017, 08:50 AM
  #55
Caddyshack
Caddyshack's Avatar
I believe the Skyline boxes are actually 25kg heavier. I was told by quite a few sources that the syncros do not like to be rushed so if you shift too quick you can damage them and then you get the crunch on change, IIRC it is 2nd to 3rd that is the often hit one.
I can just about lift the box and move it on my own but I certainly couldn't carry it the length of my drive and I could easily do that with the Cossie box.
Old 22-09-2017, 09:40 AM
  #56
markk
markk's Avatar
The problem is the users not the box.
Expecting huge inertial force to dissipate quickly at Skyline high rpm is madness.
mine is fine, and i rally it, so mechanical sympathy is the key.
The top and bottom is, they dont break gears, MT75 does.
The alternatives are what you have or other aftermarket gearkits.
But, you dont get active centre diff.
Old 22-09-2017, 09:43 AM
  #57
Caddyshack
Caddyshack's Avatar
Agree, I would love to have my oppliger with the active centre diff, that would be perfection for me as I really liked the 2 sides the the car being able to play in 2wd mode.
Old 22-09-2017, 10:12 AM
  #58
stevieturbo
C**t
I'm sure if you really wanted ( ie ££ ) you could adapt the Skyline transfer case/drive onto the Ford boxes to allow you control over the centre diff.
Old 22-09-2017, 11:14 AM
  #59
Caddyshack
Caddyshack's Avatar
I hadn't ever thought about that. I think some of the WRC escorts had active diffs but suppose that was a whole new sequential box.
As you say, I think that would be £££££ and it is a brave move when my box already cost me £4.5k all in to then start experimenting and chopping (albeit the case is standard MT75 with just a spacer on the Oppliger "long" box)
