Head lights Ford ranger 2015
Afternoon gents,
I noticed my headlight was out drivers side so I replaced the bulb but still no light so I put the multimeter on headlight plug and I'm only getting 7.5 volts. I take it the lights are controlled via a module, which will include the daytime lights and the auto switching via the column stalk.
Anybody on here had any problems with there ranger , also an idea to where the module would be.
Thanks mark
Thanks mark
Hi yeah earth is good checked that,it's 7.5v with bulb out. When I loop a cable from other headlight lights will come on for a split second then turn off and the only way to get lights to stay on is turn turn jeep off then turn lights on then restart jeep which is a nightmare in the dark
Mark
Mark
The headlights are controlled by the body control module, if a bulb blows the module goes into a safety mode, meaning even if you change the bulb it probably won't work. You could try a module reset, disconnect it for 30 minutes or so and try it. There's also a broadcast message out at the moment saying that some aftermarket bulbs can cause short circuits in the module
