Escort handling
Escort handling
Hi all , I have a mk6 escort van with rs2000 running gear .
Problem is wen I boot it , I know I shouldn't but wen I do its frightening it's all over the road . BRAKES have been upgraded thankfully by me but I was wondering if I Decamber the rear springs wats best for the front . Any advice appreciated
I remember they suffered really bad with wishbone bushes on the front which causes them to weave all over the road when u speed up. Used to change those lower arms almost on a daily basis on customers cars at one point years ago
You can get fully rosejointed versions but they are pricey. Chucking a LSD in will probably help put the power down a bit better too if its literally just torque steer
Sounds cheap to keep you going straight
It will save you that money back in tyre wear over the years and that is cheap compared to something like a slippy diff LSD that will be over Ł1000 plus fitting and will still be an issue if the bushes are shot.
ALSO check the tyre brands, if they are cheap they will make the problem worse, use Michelin type premium brands.
Ford still sell the Royal Mail Van arms. But you'll need the Finis or a v.helpful parts guy. Not that difficult to get hold of despite what some people will lead you to believe
