Wider tyres, better grip?
Old 19-07-2017, 08:37 PM
Brickhouse
Brickhouse's Avatar
Default Wider tyres, better grip?
I changed my wheels on my Mondeo V6 from some standard 205/50/17's to some 225/40/18's. Due to the extra width on the 225 tyres would I be right in thinking there will be a bit more grip or is not the case?
Old 19-07-2017, 09:22 PM
cossynut2
cossynut2's Avatar
You should get some extra grip as there will now be more tyre contact with the road.
Old 19-07-2017, 11:32 PM
Caddyshack
Caddyshack's Avatar
As above, yes but only if we are comparing apples with apples I.e. Nexan ditch finders compared to Michelin pilot sports will give a very different outcome.
Old 20-07-2017, 10:53 AM
cossynut2
cossynut2's Avatar
Good point, if you are changing narrower, good quality tyres for some of the real cheap crap ones that are out there you could end up with less grip than you have now.
Old 20-07-2017, 11:57 AM
nigel b
nigel b's Avatar
you probably wouldnt even notice the difference on track let alone road driving
Old 20-07-2017, 12:00 PM
Brickhouse
Brickhouse's Avatar
Thanks for the replies.
I had Autogrip all round on my 205's and now have Goodyear all round on my 225's.
Old 20-07-2017, 12:07 PM
Ive got a cheap set of tyres on my mondeo but according to the sricker there a grip rating B.
Old 20-07-2017, 12:08 PM
RichieST
RichieST's Avatar
With a wider tyre you will also get more rolling resistance (so mpg will be affected) and they are more inclined to tramline etc so handling could be affected.
Old 20-07-2017, 01:14 PM
Brickhouse
Brickhouse's Avatar
Excuse me if I sound a bit thick here Richie.......Does that mean MPG will be worse?
I wonder if braking may be better due to having extra rubber on the road?
Old 20-07-2017, 02:28 PM
Mashurst
Mashurst's Avatar
Might indeed make it worse, although I suspect it would be marginal.
Don't forget the rolling radius, as that will affect the mpg too. Theoretically larger radius, larger distance travelled per revolution of wheel, therefore increased mpg and vice versa. In reality it also depends on how it affects your gearing and the tendendy to change down etc., so it is again more complicated.
Increased grip is also in the dry. In the wet, there maybe an increased chance of aquaplaning due to the increased contact area, the more water the more likely. Take that to extremes and look at the tyres they use in rallying in snowy type conditions, large and narrow.
Confusing eh
Brickhouse (21-07-2017)
Old 20-07-2017, 06:25 PM
burnzy
burnzy
burnzy's Avatar
They make there own ratings up just because it has a B for wet weather grip doesn't mean it's the same for another tyre with the B rating.
Old 21-07-2017, 07:30 PM
They seem to be ok tyres. They seem to grip well.
Old 21-07-2017, 09:28 PM
20/20 vision
20/20 vision's Avatar
Location: it's not where you are, it's where you've been and where you hope to be
maybe its the case that some brands of tyres which are cheaper in Uk are cheaper because they are designed for and imported from other countries, typically far east. I was in sri lanka recently where the roads are terrible and though i dont recall the brand (but it was a really common cheap brand over here) were everywhere and i think perhaps the compound is such that it gives good grip in hotter climates but less in our colder climate. pilot sports might be too soft over there!
