Facet red top as lift pump for 550 hp YB
Old 04-07-2017, 07:48 PM
1300gt
1300gt's Avatar
Default Facet red top as lift pump for 550 hp YB
I'm looking to run a red top facet as a lift pump to my swirl pot before it gets to the 044 pump.
6-7 psi. 33 imperial gallons. 40 US.
All low pressure lines are -8 jic . 11.1mm
X4 injectors. Single rail.
Bsfc .6, but I'm running later ASNU 30 degree multi hole injectors!?
Is this pump up to the job?
Old 04-07-2017, 08:02 PM
Mark Shead
Mark Shead's Avatar
I would want the lift pump to be doing 4lt per min to keep up with injector flow.
Mark
Old 04-07-2017, 08:10 PM
1300gt
1300gt's Avatar
Would mine be leaning out?
Old 04-07-2017, 09:00 PM
Mark Shead
Mark Shead's Avatar
The swirl pot will be emptying if the flow is not enough. Not worked out what the gallons were in lt only said what it should be in lt as that's what I work with.
Mark
1300gt (05-07-2017)
Old 04-07-2017, 09:31 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
You'd need to run two of the facet pumps
1300gt (05-07-2017)
Old 05-07-2017, 11:22 AM
stevieturbo
C**t
stevieturbo's Avatar
Just use a proper pump instead of a piece of shit.
Although if using a custom tank etc...always best to design it so no swirl tank needed.
1300gt (05-07-2017)
Old 05-07-2017, 11:41 AM
Turbosystems
Super Moderator
I didn't dare post that lol
The following 2 users liked this post by Turbosystems:
1300gt (05-07-2017), Loomer (05-07-2017)
Old 05-07-2017, 11:47 AM
stevieturbo
C**t
Pumps like that do have their place....40 years ago lol
1300gt (05-07-2017)
Old 05-07-2017, 12:40 PM
Turbosystems
Super Moderator
Noah had a 2 on his ark
Adam-M (06-07-2017)
Old 05-07-2017, 01:23 PM
1300gt
1300gt's Avatar
Silly boys ! Lol
4ltr min
240ltr hour
So that's 63 US gallons ... That's what's needed?.. Facet is 40.
It's funny how I've see a curtain old ford that runs reg 10s at the strip that's got 523 plus a shot of gas .. Thats only on one red top?.. Can not see another lift pump on it !??
Old 05-07-2017, 01:39 PM
Turbosystems
Super Moderator
Silly boys ! Lol
4ltr min
240ltr hour
It only has to supply enough fuel for 10 seconds you could probably do that with an old hand pump
ajamesc (05-07-2017)
Old 05-07-2017, 08:22 PM
1300gt
1300gt's Avatar
Probably...?
I suspect your on to something here.
However it's not worth loosing an expensive engine over if I were to try some high speed runs. That's if...
Old 05-07-2017, 09:00 PM
Cosnada
Cosnada's Avatar
Tend to agree that the red top is a bit dated with other stuff more readily available.
Make sure all power supply to pumps is decent and adequate as this can have a dramatic effect on efficiency too.
1300gt (05-07-2017)
Old 05-07-2017, 09:13 PM
1300gt
1300gt's Avatar
Their has been some silly comments made. It makes me laugh.
If something is old is it rubbish?
Their is always more technically advanced methods.
Old ford gt40s on quad 48 down draw carbs could make over 400hp with much poorer BSFC than a YB..
That's on a red top. They are quite reliable.. However if it's not fit for the actual job in hand that's another matter.
Old 05-07-2017, 09:19 PM
1300gt
1300gt's Avatar
Spot on mate.
I suspect quoted delivers are at 12v, however at 13.5 or more a 40 US gallon red top, or any other could make significantly more
Old 05-07-2017, 10:51 PM
stevieturbo
C**t
So you say they quote 40GPH ( US ) for the red top. That's a feeble 160LPH
Not a hope in hell is it ever supplying a reliable 550hp...or even 450.,..maybe at a push 350hp.
But probably around 300hp worth of fuel in the real world.
I see Merlin are listing it as a 45GPH....for 240HP engines.
If you can prove/verify it actually flows more than this in the real world, then that is a different matter. But on paper....woeful.
Of course Bosch officially quote only 180LPH for their 044, but it's well know it flows substantially more.
Most other makers seem to inflate their flow figures !
Might be enough fuel in the float bowls already lol
1300gt (06-07-2017)
Old 05-07-2017, 11:05 PM
Turbosystems
Super Moderator
As I advised on post 5 you will need to run 2
1300gt (06-07-2017)
Old 06-07-2017, 10:22 AM
1300gt
1300gt's Avatar
Opinions please on the holly range?
I'm thinking about the red top quoted at 97 US gallons hour if I remember?
Cheers guys
Old 06-07-2017, 10:42 AM
Mark Shead
Mark Shead's Avatar
Cheers guys
if you have it flow test it by running it in to a can for 1min this will tell you installed flow.
Warning playing with fuel can be dangerous have a fire extinguisher to hand.
Mark
Old 06-07-2017, 01:31 PM
1300gt
1300gt's Avatar
Mark
I wasn't intending to have a cigy on the go lol.. Holly it is then!
Old 06-07-2017, 07:05 PM
steveboyslim
steveboyslim's Avatar
Unregulated blue Holly is what Ford used as a lift pump, still good today 110 GPH or 416 LPH
Steve
1300gt (07-07-2017)
Old 06-07-2017, 08:52 PM
1300gt
1300gt's Avatar
It seems the blue and black pump need to be regulated?.. They look over kill to me lol
Old 06-07-2017, 10:09 PM
turbotrev
turbotrev's Avatar
What about using a 044 pump to feed the swirl pot?
Cheers Paul
Old 07-07-2017, 07:13 AM
steveboyslim
Neither need to be regulated if the swirl pot has a return, as FoMoCo installed on some of their works competition cars.
Steve
1300gt (07-07-2017)
Old 07-07-2017, 10:29 AM
1300gt
1300gt's Avatar
Cheers Paul
Hi Paul , it's volume you need on the lift side I'm sure mate
Old 07-07-2017, 05:14 PM
turbotrev
turbotrev's Avatar
Would a 044 not do that then?
Cheers Paul
Old 07-07-2017, 05:47 PM
costina
Live long and prosper!!
costina's Avatar
As said 2 facet red tops or do what i did many years ago and run a holley blue pump this will keep up with the demand and with the return from rail back to the swirl pot will keep it topped up.
Holley blue pumps are expensive 170 quid. Then there is unions etc.
The holley is a rotor vane type and quite in comparision to a red top.
Choice is yours of cousre. And the genuine GT40 we had at work was running 2 holley pumps and rememeber they have as said float chambers and dont have a fuel return like an injected car so will not need to FLOW that much fuel.
Paul
1300gt (07-07-2017)
Old 07-07-2017, 05:51 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Blue top Holley will be fine, I've used these on high speed runs.
1300gt (07-07-2017)
Old 07-07-2017, 06:22 PM
stevieturbo
C**t
Cheers Paul
It certainly would. As long as it ties in with the design of the system. He hasnt given any details though
Old 07-07-2017, 09:22 PM
1300gt
1300gt's Avatar
Steve
Yes the swirl will be returning to main tank via a -6 jic. Main tank has a sump for lowest point of pick up.
I've spoken to think automotive with regard to holly red pump. *not ordered yet*
The blue holly is supplied with a regulator for ( carb set ups? )
Max delivery press 7psi for red. 14psi for blue. With no added reg.
So blue holly *without* regulator to charge my swirl .. ?
Would that be suitable that my return from swirl to tank is - 6 in size .. ? Or bigger ?
Proper info fellas cheers!
Old 07-07-2017, 10:37 PM
1300gt
1300gt's Avatar
I'm thinking the fuel tank breather one way valve may see too much pressure with this blue holly pump and shut off my breather ?!
If I blow directly on the breather pipe to the valve disconnected from the tank it lifts and snaps shut .. (As you would expect).
However would return pressure that will be constantly cycling from my swirl also cause this effect of "closing" my tank breather valve .. ?
I'm using a rally style shaped 12 gallon alloy rwd escort type of tank.
Old 08-07-2017, 11:15 AM
Cosnada
Cosnada's Avatar
Paul
Facet blue pumps are about Ł90 on ebay from reputable outlets. I may be looking at the wrong thing tho?
Old 08-07-2017, 11:17 AM
Cosnada
Cosnada's Avatar
Cheers Paul
I like the triple 044 holders and would consider this route.
Old 08-07-2017, 02:00 PM
costina
costina's Avatar
Holley blue pump without reg to feed swirl pot.my old setup was 1.5 litre but now 2 litre.
-6 feed and return will be fine. Make sure you fit a decent filter between tank and holley and after the 044 for injectors.
Ensure good wiring and voltages to both pumps.
Job done.
Old 08-07-2017, 05:37 PM
stevieturbo
C**t
For a suitable tank, and that isnt the low pressure side.
But again he hasnt given any details of the tank setup.
But building a tank with in-tank pumps, is pretty much the simplest and neatest solution instead of needing swirl tanks etc.
Old 09-07-2017, 08:23 AM
costina
costina's Avatar
Too be honest why dont you just buy a escort tank with a swirl pot inside and run 2 x 044 pumps to feed engine this will give ulitimate safety and will be cheaper.
I can not do this in my cortina as i wanted to retain the std tank with no external pumps visable.
I costed a custom alloy tank from concept racing and that would be around 700 quid then cost of fittings pipe etc it all adds up.
Paul
Old 09-07-2017, 08:28 AM
stevieturbo
C**t
Those generic Escort tanks with the outlet on only one side, really are a terrible design.
There would need to be some miracle work inside for them to be efficient.
Old 09-07-2017, 09:56 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Paul
I was lead to believe 2 044's is not the way to go because if one go's down your not know and be running lean. But then I'm sure one 044 fuels up to around 600 so just fit one lol. I've a swirl pot in mine as my aftermarket fuel tank surges like fuck that's fed by an 044
Old 09-07-2017, 03:13 PM
costina
costina's Avatar
Andy have you got an after market tank?
Old 09-07-2017, 03:16 PM
ajamesc
ajamesc's Avatar
Yep never had a single issue with the Ford one but it was getting really rusty. So got a none genuine one with a metal swirl in it unlike the original larger plastic one. Had it aero quipped and paint fitted it and it surged like fuck. Had to fit the swirl pot to stop it. Mines an 044 tank to swirl then 044 swirl to rail. When it go's back together I'll see what mark suggests as the rail will be now fed by an aeromotive pump
