Cosworth head prices!!!
After some info please, I've been offered a 2wd head and not sure what to value it at, spec is standard with new valve guides and valves, standard cams (no tappets) and just been rebuilt and not used, it has been freshly skimmed and the head measures 138.15mm.
What should I be looking to pay ?
Cheers in advance.
Ginger
Cheers in advance.
Ginger
I'd say about £750 due to the recent machining work but the height isn't that great.
Just sold my old 2wd head for £450, bare with no valves, cams etc measured 137.8, It ran a head saver plate for years no issues
What machining has just been done?
New guides,valve seats recut,skim?
I just paid £1700 for the same head from Julian Godfrey complete fully machined and complete except tappets.
I didn't mind paying as I know what's been done as they did it and i have comeback if there's a problem.
Cheers in advance.
Ginger
Cheers in advance.
Ginger
138.1mm id say is a little on the low side thats been skimmed a few times 750 is still to much
si
I currently need a head aswell, turned this down for £650 due to the height... https://www.ebay.co.uk/itm/282528998772
You get into trouble with the valve seats once skimmed too much.
A plate made up to replace the lost height on the head, just sits between head and gasket, might be a hillbilly fix but I know of many cars that have run for years like it
Location: it's not where you are, it's where you've been and where you hope to be
I've recently taken my old engine apart after 18 years and 30k miles. its an early 2 hole thermostat 2wd head and was 137.4mm when it went in and its still good.
there's lots of folk using low hieght heads with no problems. i reckon the likelyhood of any problems is more to do with a bad tune or overheating than anything else. that said, heads which are thicker command more money.
Heads can be used even if more than 0-5mm has been removed, this was the recommended maximum by Ford as any more would affect cam timing, emission and compression ratio on a car with standard management with standard size bowled pistons, this can all be corrected with verniers and remachining of the pistons.
Don't believe that article about valve seats falling out, that was a load of rubbish, you need to skim a lot more than 0.5mm before the seat will fall out.
The main thing are corrosion and hardness, if it has been overheated
Steve
Steve
james kiely (20-06-2017)
I think the concern is mainly heads that are less than 138.00mm
I sold a genuine RS500 head last year on eBay as I didn't know the actual value as I'd never seen one for sale separate from the block but it went on auction and sold for shy of £1300 with a 138.8 depth so based on that I believe a lot of these heads for sale are overpriced rubbish if they're beyond the recommended depth
